Gremlins in the r/t
Truck randomly hesitates or fails to turn over. battery is good. alternator is 130amp with brand new brushes in it. alternator shop says the PCM is the regulator for our units. would a hypertech 93 flash cause this?
mods:
Stock 360 block
mildly ported heads
comp cam
hughes springs, locks, and retainers
hs 1.6 rr
melling hv oil pump
m1 intake
fastman 52mm tb
mopar air cleaner and valvecovers
ac delete
mopar pph headers ceramic coated by jet hot
summit dual 11" e-fan with flex-a-lite controller
180* thermostat
4/5 drop
5% windows(soon to be redone all the way around in 5%)
rollpan
clears
Brand New Transmission, less than 500 miles
shift kit
new tires
lebra tonneau cover
panasonic cd player
kicker front door speakers
6000k hid's
hypertech- 93 octane flash, speedometer correction, rev limit +300rpm
mildly ported heads,comp cam,hughes springs, locks, and retainers,hs 1.6 rr;melling hv oil pump;m1 intake;fastman 52mm tb;mopar pph headers ceramic coated by jet hot;summit dual 11" e-fan with flex-a-lite controller;180* thermostat;shift kit;hypertech- 93 octane flash, speedometer correction, rev limit +300rpm
