I wish I could tell you I didn't buy relays and the multi-function switch.
I wish I could tell you that if I did, it fixed the problem.
I wish I could tell you I checked the fuses under the hood.
But I can't.
I got the relays and multifunction and neither fixed it, because after putting in the new switch and going to check my relays I found the fuses under the hood for brake lights and turn signal.
Both blown.
Replaced both, and wala! They work.
So needless to say, I got brakes/turn signals again.
I also got a pair of visors, so I could tweed and have custom embroidered, and they have a 3 screw triangular base, and mine have 2 screws and a rectangular base.
Dammit, 0 for 2.
Got a Power Steering Cap.
YES! finally a point for me.
I actually almost took another one first, but saw this on another kota and realized it looked like mine, the first kota I saw didn't have an engine so I took it off a Neon or something.
All and all, I should be able to sell the multifunction switch on ebay, since I got it all for less then a new Power Steering Cap cost at Autozone.
Can't complain.
They have a tailgate there w/ only a little rust, which I was debating on getting so I could shave it and do some cool taillights in it, but I passed it, though it was only 22 bux.
I may go back another day for it.
