3.9 V6 w/auto, want to convert to manual - Dodge Dakota Forum : Custom Dakota Truck Forums
post #1 of 11 Old 04-04-2012, 08:13 AM Thread Starter
Points: 15, Level: 1 Points: 15, Level: 1 Points: 15, Level: 1
Howdy.
I have a 1989 Dakota with a 3.9l V6 and an automatic. I really like this truck, but I wish it were a standard. I've found several manual transmissions for sale, but they all say they are for the 4cyl. Do they use the same transmission? Or if not, can someone give me a part number for the tranny I need. Also, if anyone knows where a good place to find one is, or has one for sale, along with the pedals & linkages & whatnot that I'd need, I'd be forever grateful.
Thanks,
Ed
Edlyn73 is offline
post #2 of 11 Old 04-04-2012, 08:22 AM
Points: 528, Level: 8 Points: 528, Level: 8 Points: 528, Level: 8
best thing to do is to go to a junkyard, find a manual, and get everything off of it you need. i dont think the v6 and 4cyl shared a trans, but i may be wrong.
kotajones318 is offline
post #3 of 11 Old 04-04-2012, 09:25 AM
Points: 84, Level: 1 Points: 84, Level: 1 Points: 84, Level: 1
Hello Ed, welcome to the forum! Your 89' had it been a standard would have come with the Aisin A535 5-Speed. If I were you I would avoid this transmission because it is known to be weak.
I have a '94 3.9 5-Speed and mine has the Aisin AX-15 which is a little better than the A535 but still a weaker transmission. If your planning on keeping the 3.9 you will probably be better off upgrading to an AX-15 or even better a NV3500. I think your 3.9 is a pre-magnum (LA) based block. So hopefully someone will chime in who knows which tranny would be best to bolt up to your block. If your planning on a V8 swap then I would at least upgrade to a NV3500.
As Kotajones said your best bet will be to find a 5-Speed Dakota and pull all of the parts you'll need from it like the pedals, etc. Where are you located? There's a nice 3.9/5-Speed Dakota that's being parted out pretty close to me that would be perfect for what your wanting to do. I know there's a few folks on here that have actually done the auto/5-Speed swap so hopefully they'll be able to break down a parts list for you.
94XCab is offline
post #4 of 11 Old 04-04-2012, 09:33 AM
Points: 345, Level: 6 Points: 345, Level: 6 Points: 345, Level: 6
That answers several questions for me as well. I'd love to convert my truck to a manual at some point, but I wasn't sure which manual transmission would work with my V6 magnum. My truck is a 94 as well.
"I'm dishonest, and a dishonest man you can always trust to be dishonest... Honestly. It's the honest ones you want to watch out for, because you can never predict when they're going to do something incredibly.... stupid."
- Captain Jack Sparrow
Franklin2012 is offline
post #5 of 11 Old 04-04-2012, 09:39 AM Thread Starter
94XCab,
Thanks for the #'s. I'm located in Washington, D.C. right now, but home is northern Ohio. If you're near either place, let me know. I'd be interested in buying some parts from the donor truck you mentioned.
Edlyn73 is offline
post #6 of 11 Old 04-04-2012, 02:33 PM
I'm in Petersburg VA but the parts truck is in Norfolk. It's a couple hours from DC. I'm thinking about going down there this weekend to pull a door and front fender from it. Shoot me a pm if your interested I'll give you some details on it.
94XCab is offline
post #7 of 11 Old 04-08-2012, 08:38 AM
What sort of part list will be needed for this type of work? Are there precut holes from the factory that are plugged where the manual will fit? Or do you have to do some cutting?
post #8 of 11 Old 04-09-2012, 07:50 PM
pinkfloydeffect's Avatar
Points: 3,876, Level: 26 Points: 3,876, Level: 26 Points: 3,876, Level: 26
A manual tranny with an automatic computer won't cause any problems?
pinkfloydeffect is offline
post #9 of 11 Old 04-10-2012, 08:43 AM
Points: 277, Level: 5 Points: 277, Level: 5 Points: 277, Level: 5
You would have a missing trans code..... Not sure if thats a CEL condition or not though
bogie is offline
post #10 of 11 Old 04-10-2012, 06:33 PM
Easy fix? I would like to know more before I do the same myself.
Tags
automatic , manual , swap , transmission
Auto vs manual Franklin2012 I have a Question? 23 04-09-2012 06:23 AM
swap auto to manual in 2000 ooredrocket00 Engine/Performance Mods 2 08-21-2011 09:36 AM
pcm swap manual to auto 99 dakota I have a Question? 0 10-12-2009 07:48 AM
convert from 2.5 to 5.9L bigred4u2c I have a Question? 6 10-07-2009 01:02 PM
