Bought a 2003 Durango disc brake 9.25 rear end looking for ideas... - Dodge Dakota Forum : Custom Dakota Truck Forums
post #1 of 11 Old 03-26-2008, 05:35 PM Thread Starter
Points: 1,363, Level: 14 Points: 1,363, Level: 14 Points: 1,363, Level: 14
I bought a rear axle out of a 03 Durango with disc brakes. I was lucky to find one on eBay for cheap.
http://cgi.ebay.com/ebaymotors/ws/eB...213913080&rd=1
I want to be able to plant the power and I knew the 8,25 would hold up. So who's done it and should I go with Caltracs or a 4 link?
Are the spring perches spaced the same? I read somewhere that the rear end was about 1/2 wider overall than mine. Is that right?
Where do I go from here???
1992 ExtCab a work in progress...
TurboKota is offline
post #2 of 11 Old 03-26-2008, 08:05 PM
brightwhiteR/T's Avatar
Points: 1,746, Level: 16 Points: 1,746, Level: 16 Points: 1,746, Level: 16
Send a message via AIM to brightwhiteR/T
damn thats cheap and it was right down the road from my gf's moms house. I would love to have been able to pick one up that cheap. I wish I would have known that was there. I have to go see what else they have got in there recently
John
brightwhiteR/T is offline
post #3 of 11 Old 03-26-2008, 08:28 PM
I've heard that the spring perches aren't the same width apart but can't say for sure. Damn! One killer deal you got that for.
post #4 of 11 Old 03-26-2008, 08:39 PM
Striped99's Avatar
Points: 2,732, Level: 21 Points: 2,732, Level: 21 Points: 2,732, Level: 21
the spring perches are not the same. I put a rango 9.25 in my old kota...shouldnt matter if ur gonna 4 link it ...overall width is the same
Striped99 is offline
post #5 of 11 Old 03-26-2008, 08:48 PM Thread Starter
Yea, I love eBay! The largest swap meet on the planet... I've had a fav-search running for a Dakota / Durango 9.25” axle for about a month and it just popped up today and I nabbed it. Hell I don't even know if it’s 2WD or 4WD axle. I figured for the price I could have the perches shaved off and new ones added where I wanted them.
But do I want leaf springs or go bags with a 4 link? This truck is not going to be a frame dragger but I would like to drop it down a few and I want to be able to hook and carry the front at the strip.
Anyone have some good pics or links to a strong 4-link suspension in an early 90 Dak?
post #6 of 11 Old 03-27-2008, 07:10 AM Thread Starter
So what was the difference in inches between the Durango and Dakota? Were the Durango's wider or narrower than your Dak's at the spring perches?
post #7 of 11 Old 04-07-2008, 06:32 PM Thread Starter
Hey, my 03 Durango 9.25 rear came in today. Man it looks big compared to the 8.25... It measures 65" WSM-WSM and 47" to the outside of each perch. Both pertchs are 2.5" wide. Perches are on the bottom (Axle on top of the springs) and it has disc brakes. I'll post some pics in the morning.
Frank
post #8 of 11 Old 04-07-2008, 06:57 PM
Striped99's Avatar
nice man...i wish i could have found disc for my rear before i got the pattern switched..didnt have enough money at the time...i can always do it later on..just have to drill the new rotors
post #9 of 11 Old 04-09-2008, 01:07 PM Thread Starter
Here it is... Nice strapping, don't you think? Most of the tie raps were ripped and pulled through. This bitch is heavy! This was a 2WD 2003 Durango.
post #10 of 11 Old 01-19-2011, 08:38 PM
Points: 823, Level: 11 Points: 823, Level: 11 Points: 823, Level: 11
Been buying a load of stuffs via ebay some worked with me mostly not, tried other vendors really gave me the best reliable parts.
__________________________________________________ ___________________________________
Ignition Coil/Control Arm Kit/Crank Position Sensor/Brake Disc/Vent Visor/Bug Shield
boydfoose is offline
rear disc brake conversion wolfeman I have a Question? 2 03-07-2008 09:03 PM
