engine swap 4.7 to 5.2 or 5.9 - Dodge Dakota Forum : Custom Dakota Truck Forums
post #1 of 10 Old 08-21-2010, 12:06 PM Thread Starter
Points: 40, Level: 1 Points: 40, Level: 1 Points: 40, Level: 1
Send a message via Skype™ to superfly080780
i have a 2000 dakota crew cab 4x4 with the 4.7 magnum i've done been through 2 engines in 2 years. it cost too much to fix them i was wondering if i could put a 5.2 or a 5.9 in it what won't
match up?
superfly080780 is offline
post #2 of 10 Old 08-21-2010, 12:37 PM
Blown287's Avatar
Points: 1,724, Level: 16 Points: 1,724, Level: 16 Points: 1,724, Level: 16
Have you thought about one of the Hemi engines? 5.7L, 6.1L, 6.4L lol they keep comming. If I were to execute a motor swap I would either go to the G2 4.7L or one of the Hemi engines.
5.9Ls have a huge aftermarket also so that wouldn't be a bad swap either.
Paxton Novi 1000 Supercharger, 14psi Blower Drive Pulley, Alcohol Injection, KRC 224 Cams, Edge 3000 Stall, JBA Headers, Spintech Cats, Borla Dual Exhaust, 2-Bar Map, SVT #39 Injectors, Torque Dampers, 4.10 Gears, Fastman 69mm TB, SCT Tuned by Hemifever
Blown287 is offline
post #3 of 10 Old 08-21-2010, 01:50 PM
it will be a very difficult swap to go to a magnum engine from a 4.7 since the don't share anything.... your better off just getting another 4.7
post #4 of 10 Old 08-21-2010, 02:09 PM
917
I HATE SPAMMERS
Points: 14,990, Level: 53 Points: 14,990, Level: 53 Points: 14,990, Level: 53
Welcome to the site............
917 is offline
post #5 of 10 Old 08-21-2010, 02:17 PM Thread Starter
ok well i found a 5.9 out of a 00 dodge durango4x4 he wants 600 dollars for the engine. it has 52000 miles, i can have tranny harness and ecu out of it if i need them. will my tranny bolt on to the 5.9 same year ?
post #6 of 10 Old 08-22-2010, 08:24 PM Thread Starter
i already have a gen 2 4.7l engine already its a 2000 model engine. i found a 2000 model 5.9 in a wrecked durango for 600.00 dollars it has 52000 miles and the guy told me he would sell the tranny and the wire harnees along with the ecu if i need them what do u think?
post #7 of 10 Old 08-23-2010, 04:01 PM
If you can get everything out of the durango you might be able to make it work.... that's if the 2000 4.7 used a 3 wire BUS like the other engines and not a 1 wire like 01+ trucks
IF that is the case you'll need... complete engine (all accessories too), trans, engine harness, motor mounts, drive shaft, probably the trans cross member too. Pay close attention to the O2 sensors (number and location) on the Durango as well.
I still think your better off getting another 4.7
post #8 of 10 Old 08-23-2010, 08:28 PM
RustyCoupe's Avatar
Points: 754, Level: 10 Points: 754, Level: 10 Points: 754, Level: 10
He's right the 4.7s share nothing with the 5.9s and it will be a major ordeal to swap everything. Better plan on just buying the entire truck and having it at your disposal to pick anything you might need off it. If you were going from a 3.9 to a 5.9 it could be done in a weekend, but the 4.7 swaps are alot more involved as the mounts (trans/engine) and linkages are diffeent along with ALL the wiring.....
Good LUCK though!!!
_________________________________
2000 Dakota Sport 3.9, 2" Reflexxion Cowl Induction Hood, STREET SCEENE GEN2 Front Bumper, Shaved Door Handles, Clear corners, Thrush twochamber muffler 2 1/2" duals, Sir Michaels Roll pan, LED Taglite (daily driver)
1934 Plymouth Coupe 454/th400, 10" 3500 stall, 4.10s, Moser axles, Full MSD ignition, 4" drop axle, reverse eye spring, '40 spindles/bones,4-link, Driveshaft loop, M/T Radir Cheater slicks
RustyCoupe is offline
post #9 of 10 Old 11-03-2010, 01:53 AM
Points: 3, Level: 1 Points: 3, Level: 1 Points: 3, Level: 1
match up?
I suggest that 5.9 is good. I used it and until now I don't have any problem in it.
playtimeover is offline
post #10 of 10 Old 05-28-2015, 09:02 AM
Points: 1, Level: 1 Points: 1, Level: 1 Points: 1, Level: 1
So I have a 2000 dakota with the 4.7 I put a 5.2 in it I just can't get around that the motor mounts are different the 4.7 arnt straight across from each other like 5.2 or 5.9 any ideas
tdtravis is offline
Engine Swap tripster07ak V8 Performance 10 12-31-2010 04:39 PM
engine swap. will it work? rockstarking12 Engine/Performance Mods 9 03-29-2010 04:20 AM
Evil R/T Engine Swap Concept - 360 MAGNUM CRATE ENGINE — 390 HORSEPOWER Swifte V8 Performance 13 03-16-2010 03:03 AM
engine swap questions. grid_lock I have a Question? 19 12-18-2009 04:51 AM
Suspension or Engine Swap cajunmp I have a Question? 1 12-28-2008 11:14 AM
