1988 3.9L Tune-Up Advice? - Dodge Dakota Forum : Custom Dakota Truck Forums
post #1 of 19 Old 09-09-2011, 06:00 PM Thread Starter
pinkfloydeffect's Avatar
Points: 3,876, Level: 26 Points: 3,876, Level: 26 Points: 3,876, Level: 26
Question 1988 3.9L Tune-Up Advice?
I have a 1988 with only 71K on it, so I want to do the best tune up I can. The oil was just changed last year, just cheap store brand oil (Autozone or Advanced Auto). Is it too late to switch over to a fully synthetic oil?? Maybe if I flush it out before I switch it over with something??
I'm going to change the spark plugs, what are the best? Would anyone recommend some sort of fancy crossfire 4 way plugs?
K & N air filter of course...
Is it too late to swap my transmission fluid over to full synthetic too?
I need to replace my radiator anyway so I will drain and fill with some sort of Prestone.
Should I Seafoam the engine??
Thanks
pinkfloydeffect is offline
post #2 of 19 Old 09-12-2011, 09:37 PM
slade's Avatar
Points: 1,960, Level: 18 Points: 1,960, Level: 18 Points: 1,960, Level: 18
the oil was changed last year? you know its like september pf 2011 has the truck been run alot ot has it sat? and you can change to synthetic at anytime it wont hurt anything and when was the last time the tranny fluid was changed and it was flushed? prolly never if it was me id have it all done and unless your building a stout engine your only gunna waist money with thoss 4 point star fire bullshit plugs and if its been sitting flush the block out with a garden hose and get that crap old coolant out and fresh stuff in
slade is offline
post #3 of 19 Old 09-12-2011, 09:59 PM Thread Starter
Yeah it was only driven on the weekends or to the parts store down the street, it's only got 70k (1988)
I don't think the trans fluid has ever been changed, is that ok to go synthetic too?
What about Seafoam? I can't see how it could hurt any...
post #4 of 19 Old 09-12-2011, 10:26 PM
slade's Avatar
i wouldnt worrie about the seafoam its till low miles realtivly and i use synthetic its the best there is i use ot because i take it from work but change the oil ever 3-5 thousands miles its really prefrence but some ppl go longer because they use synthetic
slade is offline
post #5 of 19 Old 09-13-2011, 10:34 AM Thread Starter
Don't worrie as in no harm or don't even bother? (Seafoam)
post #6 of 19 Old 09-13-2011, 10:53 AM
slade's Avatar
dont bother .. you can it wont hurt i just wouldnt idk its ur call
slade is offline
post #7 of 19 Old 09-15-2011, 06:59 PM Thread Starter
I was told I should get Mopar plugs since its a Chrysler product, would something like Bosch really be any different?
post #8 of 19 Old 09-15-2011, 07:47 PM
slade's Avatar
no spark plugs are spark plugs untill ur going high performance do a tune up fuel and oil filters rebuild that carb ... it is carbed right? not tbi? still clean it and get the right size fuel lines on it see if that stuff helps ur problem
slade is offline
post #9 of 19 Old 09-17-2011, 09:48 AM Thread Starter
Before I go back to replacing fuel lines, I figured I would get new plugs and try to clean out the fuel system + jets/carb with Seafoam recommended by a mechanic. So I put one can in half a tank of gas, haven't seen a single puff of smoke yet. Says one can per 8-25 gallons of gas, so I figured one can to a half tank makes for a potent mix. I was told stock plugs were copper tipped, so they set me up with some Bosch Platinum Plus. It has stalled out since the Seafoam application, so with these plugs we will see if it still has the problem by the end of this tank of gas. If it continues I have to choose between disassembling the carb or replacing my fuel lines again, when it has this starting problem I noticed the check engine light flashes on and off while I am cranking, but not when you start it without the problem...
post #10 of 19 Old 09-25-2011, 06:07 PM Thread Starter
Are these anything I should consider replacing, they look like filters?
There is a black thing connected to this one with a hose:
Another on the back of the carb:
1988 dakota...new interior, etc ufvj217 Styling Mods 142 09-06-2014 04:35 PM
dodge dakota 1995 v6 3.9 after tune up car runs rough? johnno0213 I have a Question? 3 06-23-2011 06:02 PM
Cheap Tune Up for V6 cmagrey12788 For Sale 0 06-07-2011 07:10 PM
1988 dodge dakota F/S 800 obo layindakota98 For Sale 16 05-13-2010 04:38 AM
test and tune at darlington dragway godspeed South East 2 02-23-2010 05:42 PM
