Go Back   Customdakotas.com Forums - Dodge Dakota Discussion Forum > Dakota Discussion > I have a Question?
Old 05-23-2009, 06:16 AM   #1
grtrat1's Avatar
Points: 1,165, Level: 13 Points: 1,165, Level: 13 Points: 1,165, Level: 13
Dakota stops running
1994 Dakota 2wd ext cab 3.9 auto... Truck has been running great since I built it.. I had a annoying exhaust leak and finally found out it was coming from that pipe that goes from the pass exhaust manifold to the back of the intake. It was split right by the tranny tube.. So I wiggles the pipe and it broke off the peice that bolts to the exhaust manifold. I took a short bolt and welded it to the opening of the peice that bolts to the exhaust manifold (left the pipe end alone).. Since then my truck has just quit running after about 10-15 of run time..I put it in park and it will crank right up..
Is this just a coincidence and maybe something else is wrong or do I need to replace that pipe?
Thanks
Chad
Issue with a 94 Dakota 99YelloDak I have a Question? 2 01-06-2009 08:04 PM
Bored at work and found these for sale 01Dakota For Sale 2 01-06-2009 12:09 PM
95 Dakota running rich Forever Dodge General Dakota Discussion 3 10-30-2008 05:52 PM
Some Dakota Stuff Jasonb61 For Sale 5 08-15-2008 05:28 AM
