Go Back   Customdakotas.com Forums - Dodge Dakota Discussion Forum > Dakota Discussion > I have a Question?
Old 07-06-2009, 04:37 PM   #1
rollinkota18's Avatar
Title: kotarollin18
Points: 746, Level: 10 Points: 746, Level: 10 Points: 746, Level: 10
Arrow Converting bolt pattern (early gen)
my 95 dakota has the dumbass 6x4.5 lug pattern, so instead sifting through the mountains of wheels im just going to convert it to some kinda of a 5 lug pattern, nothing fancy. does anyone know a good way to do it? im just putting new rotors on the front, but idk bout the back, any ideas?
Old 07-06-2009, 05:03 PM   #2
Points: 8,540, Level: 39 Points: 8,540, Level: 39 Points: 8,540, Level: 39
Activity: 68% Activity: 68% Activity: 68%
well new hubs up front (rotors have hub/unsealed bearing) from a 1st gen 87-91 are 5x4.5 bolt pattern. direct swap since your spindles use the same brake calipers as a 1st gen
the rear couple options, either:
A-find a 1st gen dak and steal the entire rear end (junk yard or oem repop)
or B- get new axles made (5x4.5) to accept the spline of your rear(29spl).
the only down side is that the 1st gen is a 27 spline rear (make sure to get the 8.25 and not the 7.25 rearend) 5x4.5 bolt
while your 2nd gen is a 29 spline 8.25 rear (6x114.5 bolt pattern)
if you really want custom that can hold power...dana 60 (which will have to be narrowed to your spec) dana60 are what most mopars(car & truck 2 dif style of dana60) came factory with and that was a 5x4.5. not to mention easy conversion to disc brakes and more selection of ring/pinion packages
Old 07-06-2009, 07:25 PM   #3
Points: 2,858, Level: 22 Points: 2,858, Level: 22 Points: 2,858, Level: 22
Activity: 72% Activity: 72% Activity: 72%
he might have an easier time finding an 8 3/4 out of an old b-body than the dana 60. they were pretty stout too, and came with 5 on 4.5 also. it would also have to be narrowed.
Old 07-07-2009, 06:12 AM   #4
Points: 4,181, Level: 27 Points: 4,181, Level: 27 Points: 4,181, Level: 27
Activity: 2% Activity: 2% Activity: 2%
Actually a B-body 8 3/4 dosen't necessarily need to be narrowed, I've got one out ofa 67-69 body and it is exactly two inches shorter than my 8.25 from my 87 truck. I'm going to run it as is for now, and then see if I need to narrow it or not. Keep in mind that bodies differed in track widths from pre 65 to post 65-70, and 70-73. You also have the option of running 70 and on A-body 8 3/4's which are approximatley 28.9 inches track width. I have some articles on all of this if you want them, I'll post the links to them later. The easiest 5 lug bolt pattern to go to is the 5 on 4 1/2 because of the wheel selections available, and the fact that ford and chrysler both uses it, along with toyota.
6 lug bolt pattern def4life I have a Question? 5 04-04-2009 04:07 PM
6x4.5 bolt pattern??? Twisted93dak I have a Question? 5 11-06-2008 07:06 PM
changing bolt pattern help AM*E*LL I have a Question? 12 11-28-2007 11:49 PM
changing bolt pattern costlydakota Suspension Forum 8 03-31-2004 06:28 PM
Bolt pattern Nikon44 General Dakota Discussion 1 01-23-2004 11:57 AM
