pinion shims - Dodge Dakota Forum : Custom Dakota Truck Forums
post #1 of 31 Old 04-27-2010, 08:38 PM Thread Starter
jacob's Avatar
Points: 3,137, Level: 23 Points: 3,137, Level: 23 Points: 3,137, Level: 23
pinion shims
how big of a drop can i go before pinion shims are necessary?
jacob is offline
post #2 of 31 Old 04-27-2010, 09:43 PM
the search button up top would be the best bet.....been covered many times
post #3 of 31 Old 04-28-2010, 03:27 AM
hynge's Avatar
Points: 3,985, Level: 26 Points: 3,985, Level: 26 Points: 3,985, Level: 26
when i had a 5/7 drop...i did not use shims. i never blew out a U joint and drove like that for at least 25K miles
01 dakota
91 cherokee
03 dodge diesel
98 volvo s70 (new dd)
hynge is offline
post #4 of 31 Old 04-28-2010, 06:56 AM
SolidStateS15's Avatar
Points: 2,129, Level: 18 Points: 2,129, Level: 18 Points: 2,129, Level: 18
Send a message via AIM to SolidStateS15
it's not the u-joints you need to worry about, if that's all it was then it wouldn't be a big deal. you need to worry about the rear end if the pinion angle changes.
, DD
85 Toyota Supra MKII, Project
SolidStateS15 is offline
post #5 of 31 Old 04-28-2010, 10:18 AM
hynge's Avatar
i really think the pinion will be fine. i have shims on my jeep beacuse i had driveline vibrations.
ive never seen anyone have shims on a lowerd truck...but i could be wrong
01 dakota
91 cherokee
03 dodge diesel
hynge is offline
post #6 of 31 Old 04-28-2010, 01:52 PM
yeah it's more of an issue with higher lift kits, but you may get away with it by lowering within normal amounts. if you want to lay it on the ground then that would be a diff story, but of course it's not like it would be driven like that.
, DD
post #7 of 31 Old 04-28-2010, 02:16 PM
hynge's Avatar
i agree ^
01 dakota
91 cherokee
03 dodge diesel
hynge is offline
post #8 of 31 Old 04-28-2010, 07:31 PM Thread Starter
jacob's Avatar
i mean i wanna do at least 6 inches in the back
jacob is offline
post #9 of 31 Old 04-28-2010, 07:36 PM
hynge's Avatar
this is what my truck was when it was static....no problems what so ever. i drove to cali and back to MD. u should be fine
01 dakota
91 cherokee
03 dodge diesel
hynge is offline
post #10 of 31 Old 04-29-2010, 03:25 PM Thread Starter
jacob's Avatar
ok bro thanks a million
jacob is offline
Pinion angle question, and other questions about going lower 03stampede Suspension Forum 7 04-03-2010 09:03 AM
Pinion Angle BP98Dak Suspension Forum 8 01-24-2010 02:17 PM
question about rack and pinion 97 kota I have a Question? 5 03-06-2009 01:39 PM
Anyone replace the Pinion seal? XxLoFnKtAxX I have a Question? 5 01-09-2008 08:15 PM
Rack & Pinion NDADIRT Suspension Forum 1 05-25-2004 10:23 AM
