03-03-2008, 06:53 AM
Title: Bal-LaL-LoP!!!
Custom Bux: $255.54
front end solution
I think I have a cracked a-arm because my passenger side, front sqeaks and creeks prety badly. I thought it just might be my shock, which is trashed anyway. Can anyone help me with this/
This is important because i'll need to know what kit to buy for my 2/3. I was gonna buy djm drop, but if it's my a-arm I was going to buy the a-arm kit to replace it.
Originally Posted by Starscream
also forgot to put rubbers on my hands.
03-03-2008, 08:12 AM
Title: 145.7db with one 12" sub
Custom Bux: $9.08
it could be a lot of things...balljoin, wheelbearing maybe, something loose. just jack it up and give it a good looking at
PRECISION AUDIO
PM ME FOR ALL YOUR AUDIO NEEDS.
-HEADUNITS-SPEAKERS-SUBS-WIRING-FUSES-DOUBLE DINS-FLIP OUTS-DVD PLAYERS-SCREENS-BOXES-EQUALIZERS-AMPS-ALARMS
HID look headlight bulbs $25 shipped
03-03-2008, 10:27 AM
Title: money bagz
Custom Bux: $120.70
yeah i dought it's a cracked arm. all the weight on that you would see it separating. could be old bushings maybe throw some grease on them. don't get djm arms though man. those things are so dangerous how they made them. atleast the 3" arms are because they just drug the ground if i bottomed out.
bridge lips suck: third rack & pinion this year
03-03-2008, 11:17 AM
Custom Bux: $123.93
id guess ball joints if youve never replaced them...but my old upper control arms bushings used to squeek too
03-03-2008, 11:24 AM
Custom Bux: $123.93
If you run a large enough tire they wont touch the ground....i set my truck up in front using the stock RT wheels and tires 255/55/17s and the arms were 1/2 inch off the ground....Im not gonna use a tire that big tough so mine might hit..o well...if i had a tubing bender id make my own
03-03-2008, 11:25 AM
Custom Bux: $255.54
Ill check that out. I'm hoping it's partly my shock b/c my truck sits kind awkward too. I notice the left front is slightly lower than the right.
I'll try replacing or greasing the bushing. I've done any maintenance in that area of the truck before
03-03-2008, 01:41 PM
Custom Bux: $9.08
that'll be your spring not your shock. if your shock is what is holding up your front end, then you shouldn't be driving the truck
PRECISION AUDIO
03-03-2008, 06:37 PM
Its probly your bushings....my truck is squeakin like a sob on the drivers side also n im almost positive thats what it is
03-03-2008, 08:00 PM
Custom Bux: $276.08
the ball joint will make more of a popping sound. the bushing will creek if your getting alot of front end movement. the shock shouldnt be makign any noise. if its sitting lower one side then the other its likly the spring and it will make a creeking noise if its broke. my dads old dak broke a spring and it creeked terrible
03-03-2008, 08:02 PM
Shit i wonder if thats what happend cause im gettin a nasty creek
