07-12-2008, 05:07 PM
Custom Bux: $19.17
how much air
just put bags in front. but it takes around 120 psi 2 get the truck up . how much does every one else need. also what kind of valves do u use thanks
07-12-2008, 07:26 PM
Custom Bux: $106.10
for me 85 psi is ride hight. i use smc 1/2" fills and 3/8" dumps. i run 90-115 psi for roads that i dont know since ride hight for me is balls low. thats with my 4.7L V8, and re7 slams all around.
07-12-2008, 08:26 PM
70-75PSI is a low ride height and 80-85PSI is an elevated ride height for me running SMC 1/2" fill and dumps. Running a V6 with Slam Specalties RE-7's up front and Firestone sleeve bags in the rear. Probably why my pressures are so low. What are you running for bags and what do you have for a motor? The valves should have nothing to do with it really but the motor weight and the bags you have will make a difference. 120PSI still is really frigg'in high though. Are you sure your air gauge is reading right?
07-12-2008, 08:46 PM
also depends on you bags, smaller diameter will need more to lift
07-12-2008, 11:07 PM
Custom Bux: $50.53
i usually run with like 100 psi, unless im rollin gangsta lean then like 180 in the front
07-13-2008, 02:41 PM
Custom Bux: $18.23
in the front i run anywhere from 100-120 (1/2 parker valves, 2500 lb firestones)....but i also have djm drop arms on the front....
07-13-2008, 04:50 PM
Custom Bux: $123.93
i roll at around 90 on a smooth road.thats about 1" off the ground..i have to go to 120 to turn tight cuz my wheels rub my djm arms at a low ride height..ive got a 5.9...
07-13-2008, 09:25 PM
Custom Bux: $55.32
I usually run at about 80-85 psi which is pretty low, I pushed a rock about 30 feet tonight as I slowed to a stop sign. It does take a tank pressure of about 110 before it will lift off the ground though.
Its only illegal if you get caught..
07-15-2008, 07:56 AM
Title: ^^tweekin^^
Custom Bux: $129.72
i'm off the ground at 75 psi, ride height at 80 psi, and fully raised at 150 psi
now the rear hhahahaha.......10 psi to raise off the ground and around 40 psi fully raised. my tank gauge doesn't really move when i raise the back up . i love bags on bars.
I lay full frame...how hard does yours lay Freaks Of Nature (md chapter)
07-15-2008, 08:10 AM
Custom Bux: $21.26
I run about 120 most of the time in the front, but I am Body droped and like a fairly high ride height. Slam RE7's all around.
