2003 Dakota axle swap - Dodge Dakota Forum : Custom Dakota Truck Forums
Suspension Mods How to articles only
post #1 of 12 Old 08-07-2011, 09:00 AM Thread Starter
Points: 1,158, Level: 13 Points: 1,158, Level: 13 Points: 1,158, Level: 13
Started 1 month ago
bcdakota is offline
post #2 of 12 Old 08-07-2011, 09:01 AM Thread Starter
On it's own wieght.....
Shackle angle good....
bcdakota is offline
post #3 of 12 Old 08-07-2011, 09:02 AM Thread Starter
bcdakota is offline
post #4 of 12 Old 08-07-2011, 09:02 AM Thread Starter
bcdakota is offline
post #5 of 12 Old 08-07-2011, 09:03 AM Thread Starter
bcdakota is offline
post #6 of 12 Old 08-07-2011, 01:42 PM
Points: 449, Level: 7 Points: 449, Level: 7 Points: 449, Level: 7
very nice... im super jealous. whats left to be done?
My Beach Cruiser Dakota
Beach Bum is offline
post #7 of 12 Old 08-07-2011, 02:26 PM
slade's Avatar
Points: 1,960, Level: 18 Points: 1,960, Level: 18 Points: 1,960, Level: 18
love it looks great
slade is offline
post #8 of 12 Old 08-07-2011, 04:11 PM Thread Starter
brakes/ bleeding brakes, steering/ mounting box, welding perches to axle/ setting driveline angles, driveshafts, shocks, tires, exhaust manifold gasket, exhaust clearnce at the front driveshaft in full droop, crossmember modifications...
bcdakota is offline
post #9 of 12 Old 08-14-2011, 10:28 PM Thread Starter
I just finished measuring every light and bumper hieght tooday and I just sat down to do an MVA search for that same info. We'll see if I am with in legal limits.
My truck sits at the same exact hieght at every same 2 points of measure. Not bad for a rookie hey?
I spent half the day driving around to get used driveshafts to cut up ( thanx Gerry) and the other half tinkering. Here it is final ride hieght. She will probably settle a bit after driving it. I scratched the shit out of the roof getting it out of the garage. I was to lazy to swap the bare rims on to avoid this. I aired the rear tires down to like 2 psi to get the clearance to get it out..lol. I also installed the rear ebreake assembly but I still need and adjuster to go between my orig and the two new ones coming from the rear.
Apparntly my rear shackles are facing the wrong direction. I will change them around tommorrow.
Here she sits ready to get flat decked into town for setting proper driveline angles and steering install.
The rear I will trim the fenders in front of the tire and cut my stock flares in half, reattatch the flare where the cut is made and rustle up a used set of flares to cut a small section out to fill in the gap. Then just a little body work to make it look original.
It won't be long now. My only limiting factor is the fact that I am getting broke fast.
bcdakota is offline
post #10 of 12 Old 08-22-2011, 11:26 PM Thread Starter
Here it is last tuesday on the trailer headed for town. I took it to a shop to completley build the steering and set driveline angles and build driveshafts..
bcdakota is offline
92 4x4 solid front axle swap help v8dakota47 Suspension Mods 9 02-01-2011 02:08 PM
solid axle swap Keoki1978 Suspension Mods 14 03-05-2010 01:47 PM
Lowering a 2003 Dakota Anaconda9105 General Dakota Discussion 9 12-02-2009 06:02 AM
2003 4.7L Intake Manifold swap? NorCalStampede V8 Performance 4 11-29-2009 02:03 PM
axle swap from an s10? yosta218 General Dakota Discussion 20 09-10-2009 12:55 PM
