07-24-2007, 07:51 PM
Custom Bux: $106.10
why 12" tall??????????????????? why the hell does everyone keep saying that. if you get it 12" tall the stock pump will not be able use all the gas in the tank since it will be to deep. you need a tank the same height as the stock tank.
07-24-2007, 08:12 PM
Custom Bux: $29.63
Originally Posted by Calgaryguy
you must get knocked up side the head. listen to what dj wolf is telling you.
You cannot build a reputation on what you are going to do.
(photoshop by jethrostyles)
07-24-2007, 09:06 PM
Custom Bux: $123.93
I just put in a new in line pump it was cheaper than a new stock pump and now my truck actually has an inline fuel filter instead of only havin a sock on the bottom of the pump
07-24-2007, 11:07 PM
Custom Bux: $14.18
the bottom feet of my pump sit on the bottom of the tank, no issue with my pump
07-25-2007, 12:26 PM
Custom Bux: $56.18
How is 12" to deep when the factory is about 12 and 3/4 deep.
07-25-2007, 08:48 PM
Custom Bux: $106.10
since with ALL the stock pumps i have seen they are only like6 or 7 inches deep. so you end up with 3+" of gas that never get used. why buy a tank where you just have gas that can never be used, and add weight for no reason. i wasnt clear before, i didnt mean a tank same depth as stock tank. i ment to say you need a tank the same depth as the stock pump. that way all the gas will get used.
07-25-2007, 11:00 PM
Custom Bux: $14.18
raise your hand if you're taken your pump out of your tank? its a telescopic housing which will rest on the bottom, fully extended is taller than the tank, so anything taller than 12" will not touch the bottom
I think its made like that to compress is if you ever have to change the pump you only have to drop the tank half as far....but i'm a mechanic in a different field so maybe i'm out to lunch..i'm just posting what i've been up to and what works for me
07-25-2007, 11:19 PM
Custom Bux: $106.10
what the hell are you trying to get at? umm since mine is out of the the stock tank, and in a fuel cell for a couple of months. I know it depresses, but are you telling me you un clip it ad just let it slide around in the tank unclipped? I understand what your doing, and i am not trying to start anything....... but the thing your saying is working for you isn't working for me. were using the EXACT same parts, so somewhere along the lines something went wrong with what one of us did. here is my setup, look familiar?
07-25-2007, 11:22 PM
Custom Bux: $106.10
you have a part # or any specs on it?
