Go Back   Customdakotas.com Forums - Dodge Dakota Discussion Forum > Dakota Discussion > V8 Performance > V6 Performance
Old 05-19-2010, 07:50 PM   #1
Points: 1,270, Level: 14 Points: 1,270, Level: 14 Points: 1,270, Level: 14
broke engine help.
hellow all. my name is chris, have not been on in a while it sucks when you get busy. i need some help with my 98 3.9 V6, tonight i went out driving and was driving like my grandpa and my roommate that was driving ahead of me flagged me down to turn off the road once stopped i began seeing smoke come out from under the hood. so i opened the hood, once the smoke died down i began looking for the problem. there was a ton of coolant all over the top of the engine. So that led me to the conclusion that the coolant hose on top of the engine was leaking. well no sign of leaks until i look at it better tomorrow. It could also be the bypass hose that is connected to the water pump, some people have had some troubles with that. Any assistance on this would be great. i will greatly anwser any questions that you may need to diagnoss the problem further. If this has come up before i would appreciate the guidance to some post that would assists me in solving this problem. i will be searching tommorrow for other posts that could help. again thank you for all the help i will be looking/tearing it down tommorrow after school so i will check back in.
Old 05-20-2010, 03:46 PM   #2
Points: 4,124, Level: 27 Points: 4,124, Level: 27 Points: 4,124, Level: 27
Activity: 10% Activity: 10% Activity: 10%
not really much to diagnose..... start the engine and see where it's leaking from.... then fix it
More Pics of my Truck
My Drag Truck Entry
Old 05-20-2010, 07:46 PM   #3
okay cool. just so everyone knows after class i went and started the engine and nothing came out. so i started to tear it down a buddy came and lent me a hand. we both decided it was the by pass hose so we tore it down and sure enough the hose had swelled so i replaced that and the thermostat while i was down. there. you for the advice AmberFireDaK, i guess i was just wondering if there was anything special i needed to know and i really did it was fairly simple. back on the road again.
Old 05-21-2010, 05:12 PM   #4
Glad you got it done problem free....
My Drag Truck Entry
Old 05-22-2010, 05:36 PM   #5
thankyou yeah she running reall strong no issues yet.
Old 05-22-2010, 07:21 PM   #6
Title: Admin .. Serious business
Points: 12,700, Level: 48 Points: 12,700, Level: 48 Points: 12,700, Level: 48
Glad it was a simple fix and your back on the road again. I like happy endings.
Old 05-22-2010, 10:11 PM   #7
don't we all...... lol
My Drag Truck Entry
Old 05-23-2010, 06:55 AM   #8
Title: Member of Team Awsome
Points: 4,095, Level: 26 Points: 4,095, Level: 26 Points: 4,095, Level: 26
Activity: 15% Activity: 15% Activity: 15%
I thought you said this was a 3.9
1994 Dakota CC, 318 Magnum, Ported heads, M1 2bbl, CompCams 212/218, 1.6rr's, MP PCM, MSD streetfire, 180 stat, E-Fan, 52mm TB, Pacesetter Headers, Custom 2.5'' Y-pipe with Single 3'', HF cat, Autolite 9232's, Richmond 4.10 Gears w/ Auburn LSD, 3/4 Belltech Drop, B&M Hammer Shifter
engine swap. will it work? rockstarking12 Engine/Performance Mods 9 03-29-2010 03:20 AM
Evil R/T Engine Swap Concept - 360 MAGNUM CRATE ENGINE — 390 HORSEPOWER Swifte V8 Performance 13 03-16-2010 02:03 AM
Building a FI engine; things to consider. scottyp Engine/Performance Mods 0 05-03-2008 06:18 AM
check engine light... cylander 4 missfire AM*E*LL I have a Question? 6 02-05-2008 08:06 PM
Engine Swap tripster07ak V8 Performance 6 11-30-2007 06:34 PM
