92' 3.9 motor swap - Dodge Dakota Forum : Custom Dakota Truck Forums
post #1 of 13 Old 09-08-2009, 03:31 PM Thread Starter
Points: 1,292, Level: 14 Points: 1,292, Level: 14 Points: 1,292, Level: 14
92' 3.9 motor swap
i seized the 3.9 in my dakota and im getting another 3.9 for it and i was wondering what all do i have to take out.. ive got all the wiring unplugged and the rad hoses unhooked.. now i gutta unbolt the transmission and motor mounts and the clutch which i dont know much about this is my first motor swapp.. anybody got some advice or tricks to taking a motor out
1992 Dodge Dakota
3.9l v6 magnum
5 speed
2wd
92'dakota is offline
post #2 of 13 Old 09-08-2009, 04:07 PM
dont forget the fuel lines and the power steering lines... just double check everything before you start to pull it, and take your time cuz if you rush it then something will break and be a pain to replace when you put the new one in
overall pretty simple job, (especially if the front clip is off)
post #3 of 13 Old 09-08-2009, 04:36 PM Thread Starter
it should come out without taking the rad out though right? is the clutch difficult to unbolt?
1992 Dodge Dakota
3.9l v6 magnum
5 speed
2wd
post #4 of 13 Old 09-08-2009, 04:39 PM
I'de probably take the rad right out so you dont risk damaging it. Take off your fan too for some more room to work with. Like dragn said, just tripple check all your wires, hoses, vacuum lines before you just go yanking on it.
I had mine out in 3 or 4 hours with absolutly no experience in the engine removal buisness what-so-ever
post #5 of 13 Old 09-08-2009, 05:20 PM Thread Starter
another question does a 318 go right in or do you got to move stuff around and make room?
1992 Dodge Dakota
3.9l v6 magnum
5 speed
2wd
post #6 of 13 Old 09-08-2009, 05:45 PM
lifteddakota's Avatar
Points: 343, Level: 6 Points: 343, Level: 6 Points: 343, Level: 6
bolt right in im guessing the 3.9 is a 318/5.2 but short two cylinders same bore and stroke. need a cpu and new engine harness also or just wire up the extra two injector to another two that fire at the same time
lifteddakota is offline
post #7 of 13 Old 09-08-2009, 08:06 PM
I just put a 318 in place of my 3.9 a month or so ago.. Complete bolt in, if you can get one for the same price as the 3.9 DO IT! If you get the computer and harness It'll go in like stock. I bolted mine to the v6 trans and everything
Youll have to cut down your fan shroud (or run an e-fan), longer heater hoses. Theres a couple stupid things like that but nothing to big of a deal
post #8 of 13 Old 09-10-2009, 12:23 PM
Points: 6,284, Level: 33 Points: 6,284, Level: 33 Points: 6,284, Level: 33
Since you have a stick car, a 318 is swap is also going to include swapping the flywheel's, as you need the V8 flywheel with the 8 notches for crank position sensor. Also for the clutch all you have to do is disconnect the slave cylindar, which bolts up to the clutch pedal, and connect to the tran bell housing. It isn't too difficult. Pick up a haynes or chiltons, and you will see how easy it is. As mentioned above, if you are going with a 318 make sure you get the computer and wiring harness. That's about it, very easy swap to do.
87DakBuilder is offline
post #9 of 13 Old 09-11-2009, 01:25 PM Thread Starter
how am i suppost to unbolt the tanny when i can barley get my hand between the motor and the firewall?
1992 Dodge Dakota
3.9l v6 magnum
5 speed
2wd
post #10 of 13 Old 09-11-2009, 01:34 PM
Captain Cobalt
nycdak's Avatar
Points: 7,325, Level: 36 Points: 7,325, Level: 36 Points: 7,325, Level: 36
Alot of cursing and some beer usually does the trick for me.
I make custom MDF speaker rings.
nycdak is offline
