nitrous 3.9? - Dodge Dakota Forum : Custom Dakota Truck Forums
post #1 of 16 Old 01-18-2010, 06:44 PM Thread Starter
nastydak95's Avatar
Points: 279, Level: 5 Points: 279, Level: 5 Points: 279, Level: 5
Send a message via AIM to nastydak95
nitrous 3.9?
hey i was looking into getting ntrous on my 3.9with 180,000 miles it runs amazing and no smoke whatsoever but how big of a shot can i run?anybody done it before?thanks
nastydak95 is offline
post #2 of 16 Old 01-19-2010, 06:28 AM
mattedakota's Avatar
Points: 764, Level: 10 Points: 764, Level: 10 Points: 764, Level: 10
on any v6 esp on a conventional cam style a 75 shot would be max with a 50 being ideal.
Nitrous express makes a universal kit for the dodge fuel injected trucks and will give you all the jetting specs you need. Just remember that nitrous is safe if you use it wisely. No 2 mile wot runs limit the use of it to no more than a 1/4 mile to be safe. and DO NOT!!!!!!!!! RUN A PLATINUM PLUG!!!!!!!!!!!!!! Change to a ngk non platinum plug. The techs at ngk can get you lined up with the exact plug for your truck and the no2. And make sure you dont have a programer or any other mod that advanced your timing as it will cause it to dettinate. The motor will hold it fine just be wise.
1/8th mile 7.86 get some
mattedakota is offline
post #3 of 16 Old 01-19-2010, 11:50 AM Thread Starter
nastydak95's Avatar
i was thinking of a 50 shot but will it rev my motor to high?its a good truck but it still has 180,000 and im not 100% on how nitrous works ive just always opted to do motor work..
post #4 of 16 Old 01-19-2010, 12:05 PM
the motor will rev faster but as long as you shift before the revlimiter you should be ok
post #5 of 16 Old 01-19-2010, 04:21 PM Thread Starter
nastydak95's Avatar
yah i ran a 16.2 with just a mopar pcm 1.7rr and some used drag radials how much do u think the nos will help?i beat all the ricers around here but its still not fast enough for me...
post #6 of 16 Old 01-19-2010, 04:51 PM
50 shot should be about a half second off your time.. so 15.7 ish?
post #7 of 16 Old 01-19-2010, 07:09 PM Thread Starter
nastydak95's Avatar
damn..thatd be sick for a 3.9...
post #8 of 16 Old 01-20-2010, 11:34 AM
ya anywhere between 3 to 5 tenths if every things is tuned right
post #9 of 16 Old 03-07-2010, 02:36 PM
Points: 788, Level: 10 Points: 788, Level: 10 Points: 788, Level: 10
whats have u done with the motor?
dodgeracer27 is offline
post #10 of 16 Old 04-01-2010, 09:11 AM Thread Starter
nastydak95's Avatar
at the time i had a mopar computer some good plugs wires etc..i also had 1.7 ratio rockers and i used some old drag radials laying around i used at the track and if i was going to race a faster honda..
"Injection Type" Forced induction scottyp Engine/Performance Mods 5 10-14-2012 04:11 AM
Nitrous lscustoms V8 Performance 22 03-12-2010 11:48 AM
are you wondering about nitrous? mattedakota V8 Performance 0 01-12-2010 01:12 PM
Nitrous utah_redneck V8 Performance 7 11-23-2009 06:13 PM
Thinking About Nitrous On My 03 R/t 03 R/T V8 Performance 11 08-18-2008 07:31 PM
