| V6 Performance Upgrades for your 3.7 or 3.9 V6 |
02-08-2010, 01:09 PM
#11
If you turned the distributor it will throw off the fuel sync...
02-08-2010, 01:11 PM
#12
i think thats what i did how do i see if thats wrong and how would i go about fixing it
02-08-2010, 02:04 PM
#13
Title: Member of Team Awsome
Go to a shop and have them put a scan tool on it, they can tell you what your fuel sync is at. While they have the tool on it get them to check your o2 readings
1994 Dakota CC, 318 Magnum, Ported heads, M1 2bbl, CompCams 212/218, 1.6rr's, MP PCM, MSD streetfire, 180 stat, E-Fan, 52mm TB, Pacesetter Headers, Custom 2.5'' Y-pipe with Single 3'', HF cat, Autolite 9232's, Richmond 4.10 Gears w/ Auburn LSD, 3/4 Belltech Drop, B&M Hammer Shifter
02-08-2010, 02:26 PM
#14
Title: Slacker
thats what i'd go with
if you don't have the haynes or chiltons to check which step you missed
The name is Josh.
1989 FIRST GEN with goofy hub caps.
1st gen 87-91
2nd gen 92-96
3rd gen 97-04
4th gen 05-on
Originally Posted by ole-busted
I carry my Maglite as an "Equalizer" and sometime use it as a "Darkness Eliminator"
Originally Posted by madmopar
some see light, some see stars.
02-08-2010, 02:41 PM
#15
I'd start by pulling the plugs and checking compression in all cyls. That will eliminate valve damage. Next I would static set the timing. More than likely you're off a tooth with the dist. You will also want to double check firing order.
02-09-2010, 10:21 AM
#16
any one else have input
02-09-2010, 10:40 AM
#17
Title: Slacker
here is the guide to do it.
REMOVAL
See Figures 1, 2, 3, 4, 5, 6, 7, 8, 9 and 10
Remove the splash shield (if equipped).
Fig. Fig. 1: Use a Phillips screwdriver to remove the retaining screws for the distributor pickup lead and splash shield-2.5L engine
Fig. Fig. 2: Once detached, remove the splash shield on 2.5L engines to gain access to the distributor
If necessary, remove the air cleaner assembly and connecting tubes.
Unplug the pickup lead wire connector(s) from the wiring harness.
Fig. Fig. 3: Unscrew the distributor cap retaining screws-2.5L engine
Leaving the distributor wires connected, unfasten the clips or screws that retain the distributor cap and lift off the cap.
Fig. Fig. 4: Rotor alignment mark-V6 and V8 engines
Fig. Fig. 5: Remove the distributor hold-down clamp-V6 and V8 engines
Fig. Fig. 6: Remove the cap with the wires connected-2.5L engine shown
Fig. Fig. 7: Remove the ignition rotor by simply lifting it out-2.5L engine
If insufficient clearance is obtained by removing the cap with the wires still connected, all or some of the spark plug wires should be tagged and disconnected from the cap for better access.
Fig. Fig. 8: Unbolt and remove the distributor hold-down clamp
Fig. Fig. 9: Install the ignition rotor by aligning the grooves-V6 and V8 engines
Fig. Fig. 10: When fully detached, lift the distributor out of the vehicle
Bump the engine around until the rotor is pointing at No. 1 cylinder firing position, with the timing marks on the front case and crank pulley are aligned. Disconnect the negative battery cable from the battery.
Mark the distributor body and the engine block to indicate the position of the distributor in the block. Mark the distributor body to indicate the rotor position. These marks are used as guides when installing the distributor.
Remove the distributor hold-down bolt and bracket. Carefully lift the distributor from the engine. The shaft may rotate slightly as the distributor is removed. Make a note of where the movement stops. That is where the rotor must point when the distributor is reinstalled into the block.
INSTALLATION
Ignition Timing Undisturbed
If the crankshaft has not been rotated while the distributor was removed from the engine, use the reference marks made before removal to correctly position the distributor in the block. The shaft may have to be rotated slightly to engage the intermediate shaft gear (V6 and V8).
Install the distributor while holding the rotor in position, allowing it to move only enough to engage the slot in the drive gear.
Install pickup coil leads and distributor cap. Make sure all high tension wires are firmly snapped in cap towers. Install distributor hold-down clamp screw and tighten to 200 inch lbs. (22.5 Nm).
Ignition Timing Disturbed
See Figures 11 and 12
Perform this procedure if the crankshaft was rotated or otherwise distributed (for example, during engine rebuilding) after the distributor was removed.
Rotate the crankshaft until the No. 1 cylinder is at Top Dead Center (TDC) of the compression stroke. The simplest way to do this is to remove the spark plug from the No. 1 cylinder and place your thumb over the hole. Slowly turn the engine by hand in the normal direction of rotation until compression is felt at the hole.
Other ways to check for TDC of the compression stroke: The most fail-safe (and time consuming) way is to remove the cylinder head cover and crank the engine until both the intake and exhaust valves are closed. Or you could use a compression gauge to determine that as you rotate the engine, the piston is coming up on compression. Also there are specialty tools available that screw in the sparkplug hole (like a compression tester) and whistle as you rotate the engine into its compression stroke. In all cases, verify the timing mark is at 0 degrees when you believe you have found TDC.
Ensure that the indicating mark on the crankshaft vibration damper is aligned to the 0 degree (TDC) mark on the timing chain cover.
Fig. Fig. 11: Distributor hold-down bolt location-2.5L engine
Clean the distributor mounting at the engine and distributor base. Lightly oil the rubber O-ring seal on the distributor housing.
Fig. Fig. 12: Distributor hold-down bolt location-V6 and V8 engines
Hold the distributor over the mounting pad on the cylinder block so that the distributor body flange coincides with the mounting pad and the rotor points to the No. 1 cylinder firing position.
The name is Josh.
1st gen 87-91
2nd gen 92-96
3rd gen 97-04
4th gen 05-on
02-09-2010, 10:41 AM
#18
Title: Slacker
that came off of autzones site. if you register you can get repair guide for free. i think i put it for a 94 though
The name is Josh.
1st gen 87-91
2nd gen 92-96
3rd gen 97-04
4th gen 05-on
02-09-2010, 11:25 AM
#19
Title: post whore
damn. ole-busted strikes out with the manual. pfft
ok it might be a good idea
02-09-2010, 11:31 AM
#20
thanks for the help. i went through that and it still is running like shit. i think that it might be the fule sync. thats the only thing that i can come up with
Powered by vBulletin® Version 3.8.1 Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.1.0 vB.Sponsors
Advertisement System V2.6 By Branden
