Go Back   Customdakotas.com Forums - Dodge Dakota Discussion Forum > Dakota Discussion > V8 Performance
Old 01-30-2010, 01:54 AM   #1
Points: 19,071, Level: 60 Points: 19,071, Level: 60 Points: 19,071, Level: 60
Activity: 16% Activity: 16% Activity: 16%
Port supercharger or smaller TB?
so i just got my kenne bell and not even a day later i am already running into isues. I have a 72MM F&B TB that i wanted to use for the blower but its bigger than the inlet tube on the KB. Should i get a smaller TB or should i just port the inlet tube on the KB? here is a pic with the TB open showing the part of the inlet that sticks out on the left side.
There isnt that much room to grind down on the inlet, but i should be able to at least bevel it down to help smooth the air flow if i stay with this size TB. The red shows the area that sticks out.
sorry for the crappy cell phone pics
Old 01-30-2010, 04:31 AM   #2
Title: Photo Nazi/Post Whore
Points: 4,271, Level: 27 Points: 4,271, Level: 27 Points: 4,271, Level: 27
Activity: 9% Activity: 9% Activity: 9%
what does everyone else do to use it?
Have you checked dakotart.com?
Old 01-30-2010, 07:14 AM   #3
Title: Internet Fight Starter
Points: 574, Level: 8 Points: 574, Level: 8 Points: 574, Level: 8
gently port it. only go about 1/4" or 3/8" deep, just to make it a smooth transition.
Old 01-30-2010, 07:21 AM   #4
bwdakrt's Avatar
Title: Smoke Em' If You Got Em'!
Points: 2,097, Level: 18 Points: 2,097, Level: 18 Points: 2,097, Level: 18
Activity: 3% Activity: 3% Activity: 3%
Agreed! Any pertruding square edge in any air intake system whether it's in a blower, TB or intake manifold causes power robbing air turbulance. Round and smooth is good!!
Old 01-30-2010, 07:53 AM   #5
SolidStateS15's Avatar
Points: 776, Level: 10 Points: 776, Level: 10 Points: 776, Level: 10
Activity: 4% Activity: 4% Activity: 4%
Send a message via AIM to SolidStateS15
keep the 72 and smooth out the KB! otherwise you would prob have to go back to a 68mm to fit it.
01 Dak CC 4.7L 4x4 5spd, DD
85 Toyota Supra MKII, Project
Old 01-30-2010, 08:48 AM   #6
98Dak408's Avatar
Title: Donating Member
Points: 2,271, Level: 19 Points: 2,271, Level: 19 Points: 2,271, Level: 19
Activity: 1% Activity: 1% Activity: 1%
When porting heads and an intake manifold, you want the intake manifold port a little smaller than the head port to prevent turbulence from the airflow running into a possible protrusion of the head. There is some amount of play/alignment differences as the intake manifold fits onto the head and this prevents a mismatch as the intake is bolted to the head. The same should be true for your blower tube mating with your TB. You can port the blower tube a bit but make sure it is a little smaller than the TB inlet.
Even if you leave it the way it is for now it's not going to kill performance. You are under boost and the engine is force fed. Also, if you decide to go to a smaller TB in the future you shouldn't have a mismatch problem as you might by porting it.
If you do port it, ideally you want a smooth and gradual transition and not an abrupt change.
1998 Dakota R/T CC; 408 Stroker; KRC 220/230, SCT; Ported Eddy’s; M1; HiPoTek 53.6 mm TB; MP Headers; Single 3 1/2" Exhaust; Transgo; PATC 2800; Motive 4.56; Auburn LSD; Hotchkis TVS - 2/3 Drop; Sidewinder Customs 13" Viper Brakes; HiPoTek X-Brace, Driveshaft Loops, Engine Torque Strap, and Differential Cover.
Thank you for looking, Richard
Old 01-30-2010, 02:00 PM   #7
Title: AWD Dak!!! What?!
Points: 815, Level: 11 Points: 815, Level: 11 Points: 815, Level: 11
Damn it I need money
Old 01-30-2010, 03:42 PM   #8
Points: 3,048, Level: 22 Points: 3,048, Level: 22 Points: 3,048, Level: 22
Activity: 39% Activity: 39% Activity: 39%
lol. i don't see me running into this problem anytime soon.
A leader without followers is just a guy taking a walk.
Old 01-30-2010, 04:36 PM   #9
Its for a 4.7L, most people either get a R/T (5.9L) or a HEMI (5.7L). I dont know of anyone that has/had a 72mm TB and a kenne bell. The biggest TB i know of on a kenne bell is a 70MM and i think its a stock ported TB.
Old 01-31-2010, 08:06 AM   #10
say what now? you got that bass ackwards
if anything you'll want the blower opening BIGGER than the OUTLET of the throttle body.
ideally, especially when you can see it youd want it to the be same size.
The supercharger scottyp Engine/Performance Mods 10 08-27-2010 08:12 AM
4.7 Paxton supercharger Alta Boy V8 Performance 23 06-23-2010 06:30 AM
true to life electric supercharger klintok Off Topic Discussion 3 09-22-2009 09:48 PM
bag question 1 port or 2 ports and how wayneb2510 Suspension Forum 4 12-26-2008 10:03 PM
port up or port forward? trickedinferno Audio and Electrical 11 03-26-2008 09:45 AM
