| Zirgo Cooling Products Zirgo Cooling Products provides your car or truck with the cooling power it needs! Electric fans, Overflow tanks, Complete A/C Systems, we have you covered! |
05-29-2009, 01:43 PM
High Performance Cooling Fans
Maximum Force CFM
Zirgo™ fans use the latest technology and high performance motors to offer maximum force CFM, up to 3000 and a long life of smooth operation.
Black or Chrome
Zirgo™ fans are available in black and chrome allowing you to dress up or hide your fan.
High Torque Motors
For unbeatable heat, fight back with Zirgo's™ strongest motors! Zirgo's™ unique revolutionary motor designs offer low amp draw, while allowing for future performance upgrades. To ensure peak performance Zirgo's™ easy-to-remove motor allows you to upgrade or exchange your motor in the future. Simply remove 4 screws, insert the new motor, and you're done! Zirgo's™ high-torque fan motors feature sealed ball bearings and fully balanced blades to ensure low noise levels and a long life of smooth operation. All Zirgo™ fans also feature reversible blades which allow them to operate as pushers or pullers. Available with flat blade or "S" blade.
Ultra Thin Design
Zirgo's™ ultra thin design and unmatchable performance, along with a limited lifetime warranty, make Zirgo™ the optimal fan for the ultimate vehicle. Let Zirgo™ high performance fans cool you down, when you heat up!
Sealed Motors
Zirgo™ fans use the high performance sealed motors to offer maximum force CFM, and a long life of smooth operation.
Lifetime Warranty
We got you covered! When quality counts, count on Zirgo™. Only Zirgo™ Cooling Fans are backed by a limited lifetime warranty. You can be assured once your Zirgo™ Fan is installed you do not need to worry about ever adjusting, removing, or maintaining your Fan again.
FIND THE FAN FOR YOUR RIDE
07-02-2009, 02:15 PM
Title: Whisper'sR/T
Do you guys have these fans on any R/T's? I know alot of fans fall short on cooling our trucks....
I want to ditch my clutch fan, but don't have the coin for the viper conversion.
07-07-2009, 07:34 PM
Summit and ourselves sell a ton of these. Unfortunately customers do not tell us what they are working with or provide us pictures all the time.
What is the CFM rating for the Viper fans? Maybe I can put together a group buy on something comparable to the Viper fans.
07-08-2009, 09:50 AM
Title: Whisper'sR/T
I'll get back to ya on that info... that would be great to find a cheaper alternate!
07-08-2009, 09:57 AM
Title: Whisper'sR/T
Okay, so guys are having really good results with the flex-a-lite 180 fan, but they don't like the controller that comes with the flex-a-lite...
Let me know what you have that might work for us. Also, do you offer any shrouds around your fans? And whats the warranty on them?
Look forward to hearing from ya!
07-08-2009, 08:23 PM
I'm probably going to get a Black Magic 180 and SPAL controller sometime in the near future, I also want to ditch my clutch fan and upgrade the factory e-fan that is probably about useless right now. Unless you can sway me otherwise and give a better price than about 250 for a similar setup I think I've already made up my mind on the 3300 CFM black magic fan. Let's see what you have to offer, just out of curiosity for now! I probably won't drop any coin for a good month, regardless. Still in the decision stages at this point...
07-09-2009, 12:11 PM
Alright I had to make sure we were comparing apples to apples.
Currently we do not offer shrouds. We have a LIMITED LIFETIME WARRANTY on all fans and temp switches.
Here is what I have that is close to the fan mentioned above:
14" 3000 Cfm Zirgo Ultra High Performance Radiator Cooling Fan
Adjustable Temp Control Switch
Zirgo Fan Relay Kit
Subtotal: $233.99
That's $72.96 in savings
07-09-2009, 12:14 PM
For a $1 more you can upgrade to the:
16" Zirgo 3000cfm High Performance Blu™ Cooling Fan
07-09-2009, 02:31 PM
Title: Whisper'sR/T
What does the "LIMITED LIFETIME WARRANTY" actually cover? 6 months down the road, I don't want the fan to stop working cause it burned up...
07-14-2009, 02:27 PM
Covers the product not labor. If installed incorrectly it will void it. Example if the product calls for a 5amp fuse and you installed a 10amp fuse it will void it. For legal purposes we have to use the word LIMITED.
As long as you register the product on our website when you get it you should be fine if and when you need to use your warranty.
Powered by vBulletin® Version 3.8.1 Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.1.0 vB.Sponsors
Advertisement System V2.6 By Branden
