Box Tuning Calculator Download - Page 3 - Dodge Dakota Forum : Custom Dakota Truck Forums
post #21 of 37 Old 07-22-2010, 03:55 PM
ADKwitDAK's Avatar
Points: 3,489, Level: 24 Points: 3,489, Level: 24 Points: 3,489, Level: 24
Originally Posted by -Torres- View Post
it's made in visual basic, so it's a windows based program. are you using a mac by chance?
no, i am using windows xp. its an HP computer
2002 Dakota Quad Cab, 4.7 V8, Magnaflow Dual Exhaust, Halo Projection Headlights, Clear/Black Euro Taillights, all tinted windows, tinted rainguards, Jensen VM9312 Head Unit, (2) Kicker KS650.2 component speaker sets powered by Kicker 350.4, (2) 12" Kicker L7 powered by Kicker 1500.1
ADKwitDAK is offline
post #22 of 37 Old 07-23-2010, 01:31 PM Thread Starter
Points: 875, Level: 11 Points: 875, Level: 11 Points: 875, Level: 11
do you have the latest .NET framework installed?
-Torres- is offline
post #23 of 37 Old 07-24-2010, 07:43 AM
ADKwitDAK's Avatar
I did. Then when I download the box design program, my computer doesnt recognize what program it uses. I dont know what the deal is.
post #24 of 37 Old 07-26-2010, 04:45 PM Thread Starter
does a window pop up saying what to 'open with'? if so i just got asked on another forum with the same issue. it's weird...this is the only time (that i'm aware of) that this has happened. and it's happening twice at the same time lol. i'm going to try to google the problem and see what i can come up with
-Torres- is offline
post #25 of 37 Old 07-27-2010, 06:15 AM
ADKwitDAK's Avatar
ya, thats whats happening. Once I download the box program and try to open it, I get that 'open with" box and no other programs recognize it...
post #26 of 37 Old 08-05-2010, 12:02 PM Thread Starter
adkwitdak...is the file a .exe extension? it needs to have that extension in order to open properly (right click it and click properties to see. it's the 'type of file' section near the top) if not, rename it with the .exe extension. i can show you how if you have it set up to where your extensions are hidden and need to change it
-Torres- is offline
post #27 of 37 Old 08-23-2010, 05:30 PM
ADKwitDAK's Avatar
I just added that .exe to the end of the name and it worked! I wish I would have done this sooner...i used about 3 different website's calculators to make mine.....by here is an image of what mine actually is. Pretty much exactly what I figured and planned on...
Name:	box dimension.jpg -1.jpg
post #28 of 37 Old 08-23-2010, 07:57 PM
June CDOM!!
dodge_408's Avatar
Points: 5,387, Level: 31 Points: 5,387, Level: 31 Points: 5,387, Level: 31
wow just entered my dimensions on the box i just finished building and by your program and it comes out that ill be tuned to 33.75HZ
dodge_408 is offline
post #29 of 37 Old 08-30-2010, 01:35 PM Thread Starter
looks good except the port area is a little low. still might work ok for you tho
built it by chance? good tuning if so lol
-Torres- is offline
post #30 of 37 Old 08-30-2010, 02:27 PM
June CDOM!!
dodge_408's Avatar
i just looked up the specs to see how much interior space was required and threw em together and it hits pretty damn hard for being just a single 10"
