Box Tuning Calculator Download - Page 4 - Dodge Dakota Forum : Custom Dakota Truck Forums
post #31 of 37 Old 08-30-2010, 04:21 PM
June CDOM!!
dodge_408's Avatar
Points: 5,387, Level: 31 Points: 5,387, Level: 31 Points: 5,387, Level: 31
ok so one thing i cant figure out is i need to go from a round port to a slotted port how would i figure this out? My port is 3'' in diameter and 14.5'' deep
dodge_408 is offline
post #32 of 37 Old 08-30-2010, 04:22 PM
ADKwitDAK's Avatar
Points: 3,489, Level: 24 Points: 3,489, Level: 24 Points: 3,489, Level: 24
[quote=-Torres-;172109]looks good except the port area is a little low. still might work ok for you tho
I finally got it all in and it is loud as hell!!! I need to put some of my fatmat on the roof so it doesnt rattle so much! Hits the lows pretty good too...i am happy with it
2002 Dakota Quad Cab, 4.7 V8, Magnaflow Dual Exhaust, Halo Projection Headlights, Clear/Black Euro Taillights, all tinted windows, tinted rainguards, Jensen VM9312 Head Unit, (2) Kicker KS650.2 component speaker sets powered by Kicker 350.4, (2) 12" Kicker L7 powered by Kicker 1500.1
ADKwitDAK is offline
post #33 of 37 Old 08-31-2010, 01:57 PM Thread Starter
Points: 875, Level: 11 Points: 875, Level: 11 Points: 875, Level: 11
so you're going to change your port from an aero port to a slot port? just put in the dimensions of your box and use the top two boxes for the length and width of the port, then the length as normal. and dont forget to put in the number of sides the port shares with the box.
awesome!
-Torres- is offline
post #34 of 37 Old 09-16-2010, 12:02 PM
Points: 1,385, Level: 14 Points: 1,385, Level: 14 Points: 1,385, Level: 14
i built the center console box for my re se 10 with this calculator and it slams very impressed with it even only on a 300 watt amp
91eflx is offline
post #35 of 37 Old 09-20-2010, 02:20 PM Thread Starter
hell yeah! glad it worked out for ya
-Torres- is offline
post #36 of 37 Old 09-20-2010, 07:17 PM
also building one from this program for a re se 12 for an 2007 mustang with a rockford amp so i will report back later but great work all my friends are shocked.!!!!!
91eflx is offline
post #37 of 37 Old 09-30-2010, 01:50 PM
hey torres i have a question the box im building uses 3 sides for the port the port length is 19.25 the the box depth is only 13.5 so my question is that since its an L port that ia 1.5" wide which side of the port do i make 18.25 the side i cut or use the sides of the box? the cut out sheet says port length is 17"
thanks for the help
91eflx is offline
