2 Din install in 1.5 Din 1989 Dak - Dodge Dakota Forum : Custom Dakota Truck Forums
post #1 of 3 Old 01-01-2020, 10:59 AM Thread Starter
Rumpple R Stillskin's Avatar
Points: 141, Level: 2 Points: 141, Level: 2 Points: 141, Level: 2
Has anyone had luck installing a 2 din into the 1.5 din hole of Dakota's.
I am going to try so if anybody has a good idea for the bezel replacement on these let me know.
I know there is enough room for it if I cut some of the brace out of the mounting area. And I believe the existing dash bezel can be cut to accommodate the 2 Din radio. The only problem is the hole for the dash bezel in the 1.5 Din radio is wider then what I need.
Oh and Hi all from Gray Ghost.
Once I get started I will upload pictures of my process fail, or process completion.
Last edited by Rumpple R Stillskin; 01-03-2020 at 06:17 AM. Reason: Adding information
Rumpple R Stillskin is offline
post #2 of 3 Old 04-08-2020, 01:05 AM
Points: 80, Level: 1 Points: 80, Level: 1 Points: 80, Level: 1
Check out Metra if they have a double DIN kit for your truck.
rothan is offline
post #3 of 3 Old 04-14-2020, 11:22 AM Thread Starter
I did try them but no go there. I am currently trying to make a mount for the radio, hopefully it will work.
