air line size question - Dodge Dakota Forum : Custom Dakota Truck Forums
Bagged suspension Riding on air and dragin' the pavement
post #1 of 7 Old 01-27-2009, 06:04 AM Thread Starter
Points: 133, Level: 2 Points: 133, Level: 2 Points: 133, Level: 2
Alright. i skimmed the bagged section and didn't come across this. Other then the size (for you smart asses lol) what's the difference between 1/2 and 3/8 lines? What benefits and down falls do each have?
miked0002 is offline
post #2 of 7 Old 01-27-2009, 10:33 AM
Captain Cobalt
nycdak's Avatar
Points: 7,325, Level: 36 Points: 7,325, Level: 36 Points: 7,325, Level: 36
Bigger line = faster up n down.
I make custom MDF speaker rings.
nycdak is offline
post #3 of 7 Old 01-27-2009, 10:34 AM Thread Starter
Simple enough i guess lol
post #4 of 7 Old 01-27-2009, 11:07 AM
bigger line = more $$$
how fast are you trying to go?
post #5 of 7 Old 01-27-2009, 03:44 PM
well it also helps to match line. to valve size if you want fast.
like 3/8's line is more controlled fill and dump
1/2 gunna be faster
a 1/2 airline the OD is 1/2 the ID is actually closer to 3/8's so most guys will use a 1/2 line with 3/8's valve to get the most out of the valves.
personally i run 1/2 line all the way around with 1/2 valves and 3/8's dumps in front. 1/8 line for the gauges (much smaller dia and easier hide 1/8 compaired to 1/4)
post #6 of 7 Old 01-27-2009, 04:01 PM
mini trucker for life
99Lowkota's Avatar
Points: 3,535, Level: 24 Points: 3,535, Level: 24 Points: 3,535, Level: 24
Send a message via AIM to 99Lowkota
the line only plays a small part in the trucks up down movement and how fast it will raise and drop. the bigger the line the faster the flow is true, but your pressure switch is the area you really need to pay attention to.
99Lowkota is offline
post #7 of 7 Old 01-27-2009, 10:03 PM
also valve placement. The closer the valves to the bag the faster it will move up and down, and the further away the slower it will move.
djwolf37 is offline
roll pan question oogieboogieX Body Work Forum 10 09-07-2010 09:28 AM
fuel line bigrob0529 I have a Question? 10 03-27-2008 12:53 PM
Wheel size specs?? dodgep0wer Suspension Forum 3 02-19-2008 06:02 PM
the infamous wheel offset and tire size question trickedinferno I have a Question? 11 11-04-2007 12:02 AM
help a sap for tire size tkredkota I have a Question? 6 08-08-2007 07:02 PM
