Generation 1 engine swap suggestions? - Dodge Dakota Forum : Custom Dakota Truck Forums
Engine/Performance Mods How to Articles only!
post #1 of 12 Old 08-19-2011, 11:04 PM Thread Starter
Points: 490, Level: 7 Points: 490, Level: 7 Points: 490, Level: 7
looking to do a swap on my 87 dakota.
any good blocks that are preferred?
Sayoung4 is offline
post #2 of 12 Old 08-19-2011, 11:23 PM
Banned
Points: 7,230, Level: 36 Points: 7,230, Level: 36 Points: 7,230, Level: 36
426 :dunno
MOPARVICK is offline
post #3 of 12 Old 08-20-2011, 07:15 AM
Quoted: 3 Post(s)
Points: 5,385, Level: 31 Points: 5,385, Level: 31 Points: 5,385, Level: 31
There is approximatley 8 trillion threads about this already.
V8 Performance - Dodge Dakota Forum : Custom Dakota Truck Forums
318 and 360 basically drop right in... 87-95 are all the same essentially, only difference is the need for an E-fan in the first gen, or a puller in front of the rad... go at it how you will.... There isn't enough room for a belt driven under the hood of the first gen.
DwnDak is offline
post #4 of 12 Old 08-20-2011, 07:21 AM Thread Starter
so 360 would go right in? with the same tranny or completely different tranny?
Sayoung4 is offline
post #5 of 12 Old 08-20-2011, 07:32 AM
'98 dak R/T
98R/T's Avatar
Points: 2,381, Level: 20 Points: 2,381, Level: 20 Points: 2,381, Level: 20
same tranny, just need a v8 clutch and flex plate (i think)
'98 R/T
headers, CAI, lowered 2"
98R/T is offline
post #6 of 12 Old 08-20-2011, 07:42 AM Thread Starter
mine is automatic, will it still work?
Sayoung4 is offline
post #7 of 12 Old 08-20-2011, 08:09 AM
Banned
yours a v6? iirc it will bolt up, but the trans wont last long if you beat on it. it would be best to find a 727 also. its gonna be a tight fit in your truck as the nose is shorter than the 91 up
post #8 of 12 Old 08-20-2011, 12:59 PM
slade's Avatar
Points: 1,960, Level: 18 Points: 1,960, Level: 18 Points: 1,960, Level: 18
the nose is short the rad support bows out and youll need a 8 flex plate and such but the v6and 8 havethe same bell you could even go 340 if you wanted carbed like me..... get a stick real men pull levers
slade is offline
post #9 of 12 Old 08-25-2011, 01:29 PM
Banned
post #10 of 12 Old 11-05-2011, 07:28 PM
qtip's Avatar
Points: 3,602, Level: 25 Points: 3,602, Level: 25 Points: 3,602, Level: 25
In regards to the tranny comment, if you have a v6 you can use the same setup as the v6 and it will bolt right up to a LA 318. If you use a 360 you will need to use a completely dfferent setup in a first gen, because the factory clutch and bell housing are a 10.5". Also a 360 is externally balanced which right away signifies that you need a different flywheel or torque converter. When I first did a swap in my 87' I used the factory A535 5speed tranny and it didn't last very long at all but if your going to drive like your grandma you'll be okay. After I went through 2 5speed trannys I upgraded to a 727 which will bolt up to the factory tranny mount the only thing is it depends on how you engineer your motor mounts. If worst comes to worst you will just end up moving the tranny crossmember, and if you want to keep your motor cool with out using an electric fan you have just walked into buying a brand new radiator and moving the motor back even further. I would definitely recommend buying a bigger radiator anyway cause i had a mechanical fan and an electric pusher on the factory radiator and the truck would still get to about 210 in traffic. Any other questions PM me
qtip is offline
Engine swap?? maybe....suggestions/opinions KandyDakota General Dakota Discussion 9 03-19-2013 07:40 AM
Engine swap? V6Dakota V6 Performance 1 04-08-2011 05:20 PM
Evil R/T Engine Swap Concept - 360 MAGNUM CRATE ENGINE 390 HORSEPOWER Swifte V8 Performance 13 03-16-2010 02:03 AM
Engine Swap? zacotaco General Dakota Discussion 9 12-05-2008 06:22 AM
Engine swap jin-eu V6 Performance 5 03-11-2007 01:31 PM
