5 lug ? - Dodge Dakota Forum : Custom Dakota Truck Forums
post #1 of 9 Old 11-25-2010, 01:57 PM Thread Starter
Donating Member
Points: 884, Level: 11 Points: 884, Level: 11 Points: 884, Level: 11
5 lug ?
will jeep liberty axle shafts work and brakes ? the shaft on Randy's Ring & Pinion. The Differential Experts. Auto Parts & Services. is saying its 30 7/8 long and they have disc brakes and its 29 spline. the dakota says its 30 13/16 and 29 spline. so its a 1/16 to long which i would imagine would be a very simple fix and give a 5 lug
slant is offline
post #2 of 9 Old 11-28-2010, 04:02 PM Thread Starter
Donating Member
so being there is no response is the is the wrong section ? just nobody knows for sure ? if it is in the wrong section could a mod move it somewhere i might be able to get some input or hopefully an answer.
slant is offline
post #3 of 9 Old 11-28-2010, 06:24 PM
well i have never heard of swaping jeep axle to a dak just for a lug convers. maybe that y there is no response, most guys for the late gens just have new axles shafts done by moser and have the rotor/drums pluged and redrilled
post #4 of 9 Old 11-29-2010, 07:32 AM Thread Starter
Donating Member
Its not a late gen. Its a 96 still the nice boxy 1ill talk to a mechanic and see what he says and see if I can get the liberty parts and some wheels for cheap
slant is offline
post #5 of 9 Old 11-29-2010, 04:24 PM
ole-busted's Avatar
Points: 13,024, Level: 49 Points: 13,024, Level: 49 Points: 13,024, Level: 49
If it's a 96 just put a first gen axle in it
89 standard cab
93 ext cab
03 ext cab bagged
ole-busted is offline
post #6 of 9 Old 11-29-2010, 05:32 PM
titchenal bros dragNbody
96bdydrpdkota's Avatar
Points: 5,029, Level: 30 Points: 5,029, Level: 30 Points: 5,029, Level: 30
Send a message via AIM to 96bdydrpdkota
thought libertys were IRS just weld and redrill yours takes and hour and you could maybe do it on the truck and auto junk sells the stuff for the front
with out trucks you would be hungry and naked....
96bdydrpdkota is offline
post #7 of 9 Old 11-29-2010, 06:48 PM
sh*t if you have a 2nd gen that your talking maybe 200ish dollars for all 4 wheels to swap
the front hubs are interchangable with the 1st gen (5x4.5 lug pattern) the spindles are exactly the same as well as the calipers.
the rear the axle tubes are the same as the frist gen, but first gen is a 27 spline axles. so swap spiders axles and drums and bam done. just takes a quick trip to the junk yard.
btw im ASE and michigan master certified....but i love these daks and have built them over and over. i think i had a sticky in one of the sections about the 5lug swap on a early gen. the 5x4.5 pattern is the most genaric mopar pattern. you should be able to find some rims pretty cheap just keep in mid the long run if you want to tuck wheel if you ever go the bagged route you'll need a high offset
post #8 of 9 Old 11-29-2010, 10:07 PM Thread Starter
Donating Member
i def wanna bag 1 day and would love to tuck but i would much rather have a usable truck. i got a bike that i like to move around and sometimes i run bikes around for a motorcycle shop here. i do plan to bag so i can be as low as possible to help with loading 1 day. and the reason for the liberty axle idea was to keep the 29 spline and the possibility of disc brakes.
slant is offline
post #9 of 9 Old 11-30-2010, 05:54 PM
well if its just the whole axle swap then use it, you can always have it narrowed. but the front hubs are gunna be dif. cuz the newer dodge lug pattern is 5x5 or 5x5.5 IIRC
