bolt-on or welded - Dodge Dakota Forum : Custom Dakota Truck Forums
post #1 of 5 Old 02-18-2013, 08:31 AM Thread Starter
derrick91's Avatar
Points: 144, Level: 2 Points: 144, Level: 2 Points: 144, Level: 2
bolt-on or welded
is the exhaust on 91 dakota bolt-on or welded?
derrick91 is offline
post #2 of 5 Old 02-18-2013, 10:39 AM
CDOM April 2009
Points: 5,280, Level: 30 Points: 5,280, Level: 30 Points: 5,280, Level: 30
bolt on.
it's also slip fit
Originally Posted by djwolf37
SH0K0TA is offline
post #3 of 5 Old 02-18-2013, 11:44 AM Thread Starter
derrick91's Avatar
ok thanks
post #4 of 5 Old 02-18-2013, 09:36 PM
but your truck is a 91..so all your clamps and pipes are rusted solid..y-pipe bolt on. a clamp holds slip fit ypipe to pre converter..converter should be welded or clamped depending if replaced before. the muffler is clamped to intermediate pipe and there is two rubber isolators rear on muffler..and one for the tail pipe
fair warning the heat shield above muffler is known to rust out at the bolts
post #5 of 5 Old 02-19-2013, 06:46 AM Thread Starter
derrick91's Avatar
thanks for the tips i'll have to look at that to see
6 bolt to 5 bolt StreetDakota General Dakota Discussion 2 05-06-2011 04:12 PM
6 lug bolt pattern def4life I have a Question? 5 04-04-2009 04:07 PM
thrush welded drpddak99 General Dakota Discussion 5 03-15-2009 06:06 PM
new lighted roll pan & welded up tail lights wolfeman General Dakota Discussion 9 05-16-2007 07:59 AM
