Engine swap?? maybe....suggestions/opinions - Dodge Dakota Forum : Custom Dakota Truck Forums
post #1 of 10 Old 12-29-2008, 11:30 AM Thread Starter
KandyDakota's Avatar
Points: 2,567, Level: 21 Points: 2,567, Level: 21 Points: 2,567, Level: 21
Im thinking about getting rid of the ole v6 mag and going with something bigger
Its a 2000 auto........5.9, 318..etc.??
what would be the best swap? what else would i need? and about how much u guys think it would cost??
This is something i wouldnt mind doing before i finish up all the paint work this winter, so any help would be appreciated...thanks...
KandyDakota is offline
post #2 of 10 Old 09-08-2012, 05:22 PM
Points: 327, Level: 6 Points: 327, Level: 6 Points: 327, Level: 6
Send a message via Skype™ to stucknsask
i have a 318 magnum in a 95 for sale with 120 k on it
stucknsask is offline
post #3 of 10 Old 09-08-2012, 05:55 PM
turtle's Avatar
Points: 3,903, Level: 26 Points: 3,903, Level: 26 Points: 3,903, Level: 26
Send a message via Skype™ to turtle
2008 called they said learn to read
turtle is offline
post #4 of 10 Old 09-09-2012, 03:36 AM
if i were you instead of the 5.2 which is the 318, or a 360 which is a 5.9, i would suggest looking for a 440 or 383 or have someone with some tech savy give you a hand. Your best bet is a donor from a wrecker, or better yet a insurance total loss, this way you get everything you need, or almost everything you need.
post #5 of 10 Old 09-09-2012, 03:42 AM
google this website. sgi salvage, bids close every wed morning @ 730am. anybody can register online and place a bid. i have bought over 50 vehicles from them. i usually just place the min reserve bid, but it has become more competitive last few yrs. you can also look and see what the vehicels have sold for, by selecting bid results, let me know if you need any help.
post #6 of 10 Old 09-09-2012, 07:37 AM
Quoted: 3 Post(s)
Points: 5,385, Level: 31 Points: 5,385, Level: 31 Points: 5,385, Level: 31
Simple easy, super easy... do a search on here..... its drop in, plug and play.. a 318 or 360.... done and done.
and if not..
refer to turtle's above post.
DwnDak is offline
post #7 of 10 Old 09-09-2012, 08:20 AM
turtle's Avatar
Nevermind he's Canadian...they just got their first library within the last 10 years and Internet in the last 5
turtle is offline
post #8 of 10 Old 09-09-2012, 12:56 PM
Good one...
post #9 of 10 Old 03-19-2013, 06:45 AM
Points: 72, Level: 1 Points: 72, Level: 1 Points: 72, Level: 1
i'm only vaguely familiar with the 360. however, the 318 is a very good choice if you're considering a small block v-8. if you have a person that can do good machine work, they can bore the cylinders out for you which will give you some added HP. keep in mind that if you decide to have machine work done to the 318, you will most likely have to change out the crankshaft. the stock cranks are made of iron, you will probably want to go to a steel crank. there are many other different additional modifications you can go with. a lot of it depends on what you want out of the motor and how much money you are willing to spend.
92Da'kota is offline
post #10 of 10 Old 03-19-2013, 07:40 AM
when posting to the forum please look at the dates of the thread posting...this thread was origianlly posted in 2009..his truck has already been featured at sema and in minitruckin magazine
thread closed
Closed Thread
Engine Swap tripster07ak V8 Performance 10 12-31-2010 03:39 PM
Suspension or Engine Swap cajunmp I have a Question? 1 12-28-2008 10:14 AM
Engine Swap? zacotaco General Dakota Discussion 9 12-05-2008 06:22 AM
Building a FI engine; things to consider. scottyp Engine/Performance Mods 0 05-03-2008 06:18 AM
Engine swap jin-eu V6 Performance 5 03-11-2007 01:31 PM
