Having troubles getting my clutch fan off - Dodge Dakota Forum : Custom Dakota Truck Forums
post #1 of 20 Old 03-15-2010, 06:13 PM Thread Starter
daknut's Avatar
I tried removing my clutch fan today and i cant seem to stop the shaft from turning. i've never taken one of these off before so maybe im doing something wrong? Any suggestions? Sorry i dont have air tools just a wrench and a hammer.
daknut is offline
post #2 of 20 Old 03-15-2010, 06:16 PM
rick00dak's Avatar
Points: 339, Level: 6 Points: 339, Level: 6 Points: 339, Level: 6
Take some wire and wrap through a hole on the front and wrap it around the alternator bracket. Then take a big ass wrench and get to gruntin. Its regular threads so turn to the left
rick00dak is offline
post #3 of 20 Old 03-15-2010, 06:18 PM Thread Starter
daknut's Avatar
coool thanks ill try to find some wire and get that done tomorrow.
daknut is offline
post #4 of 20 Old 03-15-2010, 06:33 PM
You have to stop the pulley from turning some how.... some people us visegrips, I don't recommend that cause you can damage the pulley. there is a tool you can rent from autozone or napa that will do it. That wire trick sounds like it should work tho
post #5 of 20 Old 03-15-2010, 06:37 PM
yea it a PITA. i use a air hammer and knock it loose but i would not recommend if your not familiar with the technique or working on cars
you could even try to use an old serp belt and wrap it and hold it tight somehow (the rubber will grip really well if wrapped all the way tight)
post #6 of 20 Old 03-16-2010, 12:10 AM Thread Starter
daknut's Avatar
cool ill give this a try when i get a chance. thanks guys
daknut is offline
post #7 of 20 Old 03-16-2010, 01:40 AM
917
I HATE SPAMMERS
Points: 14,990, Level: 53 Points: 14,990, Level: 53 Points: 14,990, Level: 53
Yep almost any of that should work for the average person, but being that you are well below average, I think you should pull the motor out and shake the fan off
917 is offline
post #8 of 20 Old 03-16-2010, 03:15 AM
post #9 of 20 Old 03-16-2010, 07:01 AM Thread Starter
daknut's Avatar
Originally Posted by DRAGN94 View Post
if this doesnt work ill try the shaking thing! ROFL! LMAO!
daknut is offline
post #10 of 20 Old 03-16-2010, 07:04 AM
Points: 756, Level: 10 Points: 756, Level: 10 Points: 756, Level: 10
it can also be done with a cold chisel and a hammer same approach as air tools just take a little more effort
wekeisler is offline
Clutch Fan Removal and elect. fan unuzual kustum I have a Question? 8 02-25-2010 02:09 PM
clutch fan question JJs02DAK I have a Question? 8 11-24-2009 07:20 PM
how to take off the fan clutch? HazieD1 V8 Performance 7 11-17-2009 08:00 AM
87 Dak, clutch wont disengage....Help! smack doogle General Dakota Discussion 4 10-11-2009 10:01 AM
Replacing clutch fan w/ electric kacivic V8 Performance 10 08-12-2009 12:39 AM
