5.9 Magnum Block ID - Dodge Dakota Forum : Custom Dakota Truck Forums
post #1 of 9 Old 07-13-2010, 08:50 PM Thread Starter
RustyCoupe's Avatar
Points: 754, Level: 10 Points: 754, Level: 10 Points: 754, Level: 10
5.9 Magnum Block ID
I have to opportunity to buy a "5.9" out of a wrecked 03/04 Dakota QC that is suppose to have a 5.9 . The guy is selling the 5.9 and trans with driveshaft and the Entire PCM/Harness for $600 firm. Im not ready pull my 3.9 yet but have been talking about it for awhile. Afeter browsing Dak-Durango.com and the R/T site I came up with some swap info but little on Casting numbers...but before I get carried away I want to verify its a 5.9 first.
I'm new to the Magnum Mopar engine world and curious if the newer 360s still have 360 cast on the side of the block or if anyone can provide a link for block casting numbers.
Apparently there were 5.9s in QCs in 03/04
Im going to try to get the 9.25 w LSD outta the deal as well
Any info or advice would be appreciated........
_________________________________
2000 Dakota Sport 3.9, 2" Reflexxion Cowl Induction Hood, STREET SCEENE GEN2 Front Bumper, Shaved Door Handles, Clear corners, Thrush twochamber muffler 2 1/2" duals, Sir Michaels Roll pan, LED Taglite (daily driver)
1934 Plymouth Coupe 454/th400, 10" 3500 stall, 4.10s, Moser axles, Full MSD ignition, 4" drop axle, reverse eye spring, '40 spindles/bones,4-link, Driveshaft loop, M/T Radir Cheater slicks
RustyCoupe is offline
post #2 of 9 Old 07-14-2010, 05:01 AM
Banned
Points: 1,986, Level: 18 Points: 1,986, Level: 18 Points: 1,986, Level: 18
It will say 360 stamped on the side. I do not remember which side it is though.
jmaack727 is offline
post #3 of 9 Old 07-14-2010, 05:11 AM
SrRaV1981's Avatar
Points: 2,876, Level: 22 Points: 2,876, Level: 22 Points: 2,876, Level: 22
Check the VIN number on it. Dakota VIN Decoder
2001 Dakota 5.9 R/T CC (The Toy)
01 Lexus Is300 5sp (Daily Driver)
55 Chevy PU 283v8 4sp (Rat Rod)
SrRaV1981 is offline
post #4 of 9 Old 07-14-2010, 06:26 AM
CDOM April 2009
Points: 5,280, Level: 30 Points: 5,280, Level: 30 Points: 5,280, Level: 30
IIRC the daks with the 5.9s have a Z in the middle of the vin....
Originally Posted by djwolf37
SH0K0TA is offline
post #5 of 9 Old 07-14-2010, 01:04 PM Thread Starter
RustyCoupe's Avatar
Cool guys thanks Yea I talked to my boss and a few people on the dak-durango site and they all showed me pics of what to look for ...now just gotta find out if this thing is the real deal....
post #6 of 9 Old 07-16-2010, 09:13 PM Thread Starter
RustyCoupe's Avatar
Well I looked at the engine and its a clean 5.9
360 stamped right at the end of the block casting numbers on the drivers side...
Complete with PCM and trans...motors looked clean no leaky valve covers or anything. The driveshaft thats with it is alumium tho but I think its too long as it came out of a QC
I told the guy I'd buy it now the fun stuff of doing the swap!!
post #7 of 9 Old 07-19-2010, 05:11 AM
SrRaV1981's Avatar
post some pics when you can.
post #8 of 9 Old 06-09-2020, 05:30 PM
Points: 193, Level: 3 Points: 193, Level: 3 Points: 193, Level: 3
You bought this car? I also plan to buy a car where I will be the second owner, but I've never done it before and I'm worried that I might get into some problems with buying a used car. If you have any ideas how to check the history of a car in Australia then I would appreciate any advice.
Freddo is offline
post #9 of 9 Old 06-11-2020, 05:52 AM
Points: 535, Level: 8 Points: 535, Level: 8 Points: 535, Level: 8
I know that you can check a car using special online services by the VIN number of the car you want to buy. It's not complicated and doesn't take much time. Here https://www.quickppsr.com.au/vin-check you can find a more detailed description of how to do this and what information you can get from this auto check. I think this is a really convenient service in order to make buying a used car more secure.
Rampul is offline
Magnum 360 block info needed 93DakspoRT V8 Performance 16 04-07-2010 07:35 AM
Custom HiPoTek Magnum OEM Big Bore Throttle Bodies 98Dak408 V8 Performance 6 03-16-2010 06:51 AM
Evil R/T Engine Swap Concept - 360 MAGNUM CRATE ENGINE 390 HORSEPOWER Swifte V8 Performance 13 03-16-2010 02:03 AM
1995 360 (5.9) Magnum Block Jasonb61 For Sale 1 05-03-2009 09:05 PM
New kid on the block..... GSXReign Noobie Introductions 7 11-03-2008 06:24 AM
