super or turbo... - Dodge Dakota Forum : Custom Dakota Truck Forums
post #1 of 8 Old 01-03-2011, 09:38 PM Thread Starter
2000SLT's Avatar
Points: 729, Level: 10 Points: 729, Level: 10 Points: 729, Level: 10
super or turbo...
so i roll around with buddys who all have boost and its really buging me when they pull away haha..i wanna run between 6-10 pounds i want to know what its the best way and most price efficent to do to my truck..i know i will need injectors and fuel pump ex..i wanna stay away from boring out my pistons if even possible. anyone have sugestions or know that route i should take..im running a 4.7l with many adds,,
2000SLT is offline
post #2 of 8 Old 01-03-2011, 11:41 PM
"MR. Cut & Flip"
93DakspoRT's Avatar
Points: 5,021, Level: 30 Points: 5,021, Level: 30 Points: 5,021, Level: 30
Send a message via AIM to 93DakspoRT Send a message via Skype™ to 93DakspoRT
well they make supercharger kits for the 4.7.... but turbo kits are pretty universal and most of the time cheaper... just add in the cost of tuning when you're looking at boost kits (usually around $500)
77 aspen - project
94 Dakota-Dailydriver v6 5 speed
Originally Posted by madmopar View Post
this coming from mister cut and flip?
93DakspoRT is offline
post #3 of 8 Old 01-04-2011, 12:38 AM
95SloNlo's Avatar
Points: 956, Level: 12 Points: 956, Level: 12 Points: 956, Level: 12
boost has absolutely nothing to do with the bore of your motor.
turbo systems are generally cheaper depending on your goals. either way theres a good chunk of change to be spent. best bang for buck: nitrous. spray the snot out of it and dont tell them about it.
95SloNlo is offline
post #4 of 8 Old 01-04-2011, 08:05 PM Thread Starter
2000SLT's Avatar
depending on the how many pounds you would want to push it would be idle to bore out and get bigger pistons so the motor could withstand it. its obvious i will need bigger injectors and ex. and yes if i want a blown motor that is worth nothing i can run 20 pounds with stock pistons and see how far that gets. there alot that goes into boosting if you want to do it right. just asking for the best route to take on the stock block. i have done my research and herd the 4.7 dont hold up to well just trying to get way almost like how the lightning with the ten pounds.people who have boost please pop in..want to get this done before spring if even possible..
2000SLT is offline
post #5 of 8 Old 01-04-2011, 08:33 PM
6.9 6 speed
Sick 660r's Avatar
Points: 2,073, Level: 18 Points: 2,073, Level: 18 Points: 2,073, Level: 18
Only thing cylinder bore has to do with boost is spool time but that is really a matter of CI not just bore. Your talking about the quality of the piston not the size. Increasing your bore will only weaken your block if it can not handle the thinner walls.
sounds like you should just do a remote turbo with sct, larger injectors, and a inline aux pump.
forged 6.9 418
paxton sc
krc fuel system
SCT PRP
T56
Sick 660r is offline
post #6 of 8 Old 01-04-2011, 08:36 PM
daknut's Avatar
is it to much to ask for both??? probablly... twin turbos!
daknut is offline
post #7 of 8 Old 01-04-2011, 09:09 PM Thread Starter
2000SLT's Avatar
exactly the stregnth is what i was going for thanks for understanding were im coming from haha..remote turbo..help me out here size and kits what ill need only turbos im use to working on is 4cylinders.
2000SLT is offline
post #8 of 8 Old 01-05-2011, 04:16 AM
6.9 6 speed
Sick 660r's Avatar
Call STS. Im working on my front mount now but I've never delt with a rear mount. I know the turbine will have to be small to keep a decent spool time with the reduced back pressure. Top end efficiency will suck with the small turbine but theres not much you can do about it.
forged 6.9 418
paxton sc
krc fuel system
SCT PRP
T56
Walk through of a turbo build. scottyp Engine/Performance Mods 10 01-27-2010 08:54 AM
Turbo help lscustoms V8 Performance 7 07-16-2009 11:39 PM
I Want a turbo!! Hemiactive V8 Performance 9 04-12-2008 10:00 AM
3.9 Super Charger Or Turbo SNIPERLAMBO V6 Performance 11 09-30-2007 08:34 PM
