I'm building an 89 Dakota with a 440 big block, the previous owner cobbled a sbc in it and wacked up the crossmember and original left side mount... I need a measurement from the center of the crank to each inside frame rail.. it looks as though the engine is offset originally but I need to now if it is how much side to side.. I also need a measurement from the center of the output shaft on the trans to each frame rail.. Any help will be appreciated
Thanks,
Randi
Thanks,
Randi
