Fuel cell help - Dodge Dakota Forum : Custom Dakota Truck Forums
post #1 of 14 Old 04-14-2008, 11:58 PM Thread Starter
Points: 1,618, Level: 16 Points: 1,618, Level: 16 Points: 1,618, Level: 16
Fuel cell help
Im looking to get a fuel cell for my truck soon. I had a few questions. I got a holley "blue" electric fuel pump givin to me, problem is i dont know if it will work. I know it will work on carbureted cars but will it work on my dak? heres a link to the pump.
http://www.holley.com/12-812-1.asp
Also is there a way to get my gas gauge to work with a cell?
Does anyone have a fuel cell they would want to sell?
Thanks in advance
nvthis3 is offline
post #2 of 14 Old 04-15-2008, 05:44 AM
Points: 3,435, Level: 24 Points: 3,435, Level: 24 Points: 3,435, Level: 24
if you get a cell the same depth as your fuel pump you can use the stock pump.
and if you read at the bottom of your link it says Not designed or recommended for use with fuel injection systems
Thump3r is offline
post #3 of 14 Old 04-15-2008, 09:20 AM Thread Starter
ya I read that, but was hoping it might still work, how deep is the factory pump?
nvthis3 is offline
post #4 of 14 Old 04-15-2008, 10:00 AM
depends on your tank
mines only 8" deep since its a quad cab, but i think most are 14" deep
Thump3r is offline
post #5 of 14 Old 04-15-2008, 09:58 PM
last i checked the non QC's should be 12" deep
djwolf37 is offline
post #6 of 14 Old 04-16-2008, 01:11 PM
Points: 2,732, Level: 21 Points: 2,732, Level: 21 Points: 2,732, Level: 21
yeah 12"s is correct....ur gonna have to get a fuel pump that uts out at least 50psi....stock fuel pressure is between 48-50....that blue only puts out a max of 15 i think
Striped99 is offline
post #7 of 14 Old 04-16-2008, 03:32 PM
that pump won't work. not enough psi as for the gauge if you still use the stock pump then your fine.
post #8 of 14 Old 04-18-2008, 12:51 AM Thread Starter
Thanks guys im just gonna try to find a cell that will work with my factory pump. Anyone know a good place to get one fairly cheap?
nvthis3 is offline
post #9 of 14 Old 04-18-2008, 12:55 AM
any cell will do, just get it 12" deep and your good to go. i got mine from summit, cheapest place i found. i have a 19 gal RCI aluminum tank
djwolf37 is offline
post #10 of 14 Old 04-18-2008, 12:36 PM
Points: 1,168, Level: 13 Points: 1,168, Level: 13 Points: 1,168, Level: 13
Where are you guys mounting your fuel cells?, under bed? spare tire location?
a pic or two would be great
440Kota is offline
CEL Codes batman13 I have a Question? 14 08-16-2011 11:32 AM
fuel cell with stock pump Calgaryguy Suspension Mods 19 08-06-2007 10:42 AM
fuel cell nogee2 Suspension Forum 9 04-27-2007 09:18 PM
fuel cell set up question 1low02dak I have a Question? 10 03-02-2007 03:16 PM
New Frame CLip and Fuel Cell KaoticDakota Suspension Forum 32 06-07-2004 07:36 PM
