Brakes Are Failing - Page 2 - Dodge Dakota Forum : Custom Dakota Truck Forums
post #11 of 39 Old 02-17-2010, 10:47 AM
The parking brake is cable isn't it? That would allow it to work even though the rear brakes aren't.
If that's the case, in theory, fluid is not activating the cylinder in the drums. Definatly replace them. They're cheap anyway to buy
post #12 of 39 Old 02-17-2010, 11:10 AM
ole-busted's Avatar
Points: 13,024, Level: 49 Points: 13,024, Level: 49 Points: 13,024, Level: 49
Find the problem first. you don't want to just throw parts at it that get expensive. there is also a rear brake Abs solenoid on the frame rail that could make the brakes work fine under normal conditions but make it act up during the test. it may have a bleeder screw as well
89 standard cab
93 ext cab
03 ext cab bagged
ole-busted is offline
post #13 of 39 Old 02-17-2010, 12:45 PM
daktaspt's Avatar
Points: 1,375, Level: 14 Points: 1,375, Level: 14 Points: 1,375, Level: 14
OB hit the nail on the head here!
First thing I would do is jack up each side with trans in neutral. Tighten each adjuster while rotating the wheel (there may be a tight spot, plus they can bind) having someone depress the brake pedal every now and again. When the wheel is too hard to move easily, back off the adjuster 4 or 5 clicks. Make sure wheel spins free. Repeat for the other side. Then test.
The adjuster can not back off if all is well. You will notice when you adjust them that they adjust up easy and back off hard. It is do to the machine on the adjuster tab. Rear brakes need adjustment every so often. Less if you regularly use the park break (most models).
Frank
daktaspt is offline
post #14 of 39 Old 02-17-2010, 01:12 PM
hynge's Avatar
Points: 3,985, Level: 26 Points: 3,985, Level: 26 Points: 3,985, Level: 26
im a MD inspector.....why the hell did they not tell you why it failed??
they inspect it, fail your truck....and dont explain why???
01 dakota
91 cherokee
03 dodge diesel
98 volvo s70 (new dd)
hynge is offline
post #15 of 39 Old 02-17-2010, 02:00 PM Thread Starter
92 Dakota 3.9 2wd
KRIS05VVTi's Avatar
Points: 947, Level: 11 Points: 947, Level: 11 Points: 947, Level: 11
Send a message via AIM to KRIS05VVTi Send a message via MSN to KRIS05VVTi
yea i baught them and will be putting them on in a little while
see i knew someone else saw it like i did, i got locked up 2 weeks ago because of this....i asked the black guy (no offense to my morenos) and he at first looked at me like i'm stupid, then says in his exact words "read the fcuking paper bitch" i was like wow this guy is having a really bad day, either way he shouldn't have acted like that, so enyways i took a look at the paper and left and i saw it didn't specify anything i should visually/manually inspect so i go up to him and ask him "yo can you explain this to me a bit, well as much as you know at least" and then he just flipped out so and pushed me so i went off on him lol
so obviously i did'nt get an explanation but a night in county for battery lol
He's from Newark, I believe it. Lol
KRIS05VVTi is offline
post #16 of 39 Old 02-17-2010, 02:06 PM
Are you serious, you got locked up?
That sucks
post #17 of 39 Old 02-17-2010, 02:33 PM
"Do What You Do"
grid_lock's Avatar
Points: 3,180, Level: 23 Points: 3,180, Level: 23 Points: 3,180, Level: 23
DAMN! i smell that BS from ohio. that cop should be punched in the nostril and kicked in the throat.
grid_lock is offline
post #18 of 39 Old 02-17-2010, 02:53 PM
post #19 of 39 Old 02-17-2010, 03:03 PM Thread Starter
92 Dakota 3.9 2wd
KRIS05VVTi's Avatar
That sucks
yea they told me i was gonna spend the afternoon and night there so i just aint go to sleep lol i was scared a lil bit
what bs why would i lie?
lmmfao thats going in my sig
post #20 of 39 Old 02-17-2010, 04:46 PM
ole-busted's Avatar
wow man thats insane
89 standard cab
93 ext cab
03 ext cab bagged
Tags
brake failure
Rear Disc Brakes dodgebigblue I have a Question? 20 03-10-2010 10:34 AM
Brakes! What Can We Do To Make Them Better! cruentusanima I have a Question? 35 04-07-2009 09:55 PM
ABS brakes Andrew Thiel I have a Question? 6 12-12-2008 06:02 PM
BRAKES please help batman13 I have a Question? 10 03-03-2008 01:07 PM
rear brakes for a 95 scotish268 General Dakota Discussion 5 08-22-2006 11:58 PM
