Fog Light Wiring - Dodge Dakota Forum : Custom Dakota Truck Forums
post #1 of 11 Old 02-24-2010, 12:14 PM Thread Starter
"..to punish and enslave"
BlueDragon's Avatar
Points: 2,493, Level: 20 Points: 2,493, Level: 20 Points: 2,493, Level: 20
Fog Light Wiring
MY truck is an 05 ST, but I have switched to a color match bumper and put in the foglights. I know I have to get the connectors at the foglight end and I've already gotten the OEM switch with the foglight control. My question is will the existing harness have the wiring in it for the foglights or am I going to have to run separate wiring?
BlueDragon is offline
post #2 of 11 Old 02-24-2010, 12:19 PM
ole-busted's Avatar
Points: 13,024, Level: 49 Points: 13,024, Level: 49 Points: 13,024, Level: 49
you should probally run seperate wiring i looked into doing the same to my 06 ram and i found out the computer has to be flashed by the stealership to let you hook them up like stock
89 standard cab
93 ext cab
03 ext cab bagged
ole-busted is offline
post #3 of 11 Old 02-24-2010, 02:57 PM
daknut's Avatar
good question. beats me.
daknut is offline
post #4 of 11 Old 02-24-2010, 07:00 PM
92 Dakota 3.9 2wd
KRIS05VVTi's Avatar
Points: 947, Level: 11 Points: 947, Level: 11 Points: 947, Level: 11
Send a message via AIM to KRIS05VVTi Send a message via MSN to KRIS05VVTi
Originally Posted by 94mark3 View Post
He's from Newark, I believe it. Lol
KRIS05VVTi is offline
post #5 of 11 Old 02-24-2010, 07:10 PM
Points: 7,499, Level: 37 Points: 7,499, Level: 37 Points: 7,499, Level: 37
to use the factory switch, i think you would have to hook them into the harness. that means they will cut off when you turn your high beams on. if you hook them up with a stand-alone harness, you can make them completely independent, or do like we do at the shop, and tie them into the parking lights. then they will work with all and they will cut off when you turn your lights off.
A leader without followers is just a guy taking a walk.
madmopar is offline
post #6 of 11 Old 02-24-2010, 07:14 PM
CDOM April 2009
Points: 5,280, Level: 30 Points: 5,280, Level: 30 Points: 5,280, Level: 30
i know on the 97 and 02 of mine, all i gotta do is get the right switch (for fog light control) then get the wiring that goes from the factory harness to the foglight. then install a fuse and i'd be good to go... i'm actually workin on this now on the 02.
your truck should have the prewiring for the fog lights... but the connectors are prolly hidden
Originally Posted by djwolf37
SH0K0TA is offline
post #7 of 11 Old 02-24-2010, 07:27 PM
92 Dakota 3.9 2wd
KRIS05VVTi's Avatar
thats rite....also cant he use a 12v switched from the stock button and wire it up like my diagram!? that'll work but then again looking for which wire has a switched current is gonna be difficult no!?
post #8 of 11 Old 02-24-2010, 07:58 PM
dont want to nit pick but kris your diagram wont work. theres no power wire for the switch to "flip" the relay(its grounded on both sides). and i recommend using a switched hot wire, not directly to battery. just sayn to make it easier for someone who knows nothing.
post #9 of 11 Old 02-25-2010, 12:39 PM
92 Dakota 3.9 2wd
KRIS05VVTi's Avatar
ooops yea lemme re-do it
post #10 of 11 Old 02-25-2010, 03:42 PM Thread Starter
BlueDragon's Avatar
Thanks for all the info everyone. I think I'll look to see if it's there but just tucked away.
Low budget fog light install tcory Styling Mods 13 12-11-2018 06:31 PM
LED info, FAQs, tips and tricks brightwhiteR/T Styling Mods 4 11-11-2009 05:46 PM
low fuel light Scooby I have a Question? 7 07-17-2009 09:10 PM
LED third brake light group buy is officially on!!!! brightwhiteR/T For Sale 15 11-27-2007 07:09 PM
Ram 3rd Brake Light in Dakota 3rd Brake Light ecordell Styling Forum 4 01-09-2007 05:29 PM
