Hood latch relocation rod - Dodge Dakota Forum : Custom Dakota Truck Forums
Styling Mods How to articles only
post #1 of 16 Old 07-18-2007, 06:44 PM Thread Starter
This may or may not be of any usefull value to anyone.
But if you have a billet grill, winter front or custom mesh installed into your grill, the outside hood latch mechanism is rendered useless because of the fact that your fingers can no longer pop the outside hood latch.
I know there are kits available to get around this but for the cheap guys like me ...... This is how it's done.
Get a small piece of metal rod [18" long] and and make a 90 degree bend close to the end. Directly below that make another 90 so that the rod now has two 90's in it. The direction of the rod still should be going the same way though.
Drill a small hole in your hood latch mechanism just big enough to feed the rod, with the two 90 degree bends,through. The rod should be hanging downwards. Tiewrap the rod lengh to the middle bar on the backside of your grill loosely and put another 90 at the bottom. Cut off the excess rod.
In this way, once your interior hood latch is popped, you reach directly below the grill and push up on the metal rod to activate the secondary hood latch.
This is how you have do your secondary hood latch mechanism when you install a billet grill cause there's no way to pop the hood without it.
View of rod that has to be made up and cable tied loosely to the middle bar of your grill:
Veiw of the lower part of the rod at the bottom of the grill:
Veiw of the secondary hood latch mechanism: *note: A small hole big enough for the rod to fit through will have to be drilled in the latch.
Don't use any type of metal rod that will rust like I did in these pics. A wire coat hanger works good for this because it has a coating on it.
post #2 of 16 Old 07-18-2007, 07:48 PM
moparman89's Avatar
Points: 722, Level: 10 Points: 722, Level: 10 Points: 722, Level: 10
Send a message via AIM to moparman89
i did basically the same thing only i used a piece of 14 gauge wire, it works well
moparman89 is offline
post #3 of 16 Old 07-18-2007, 10:37 PM
Points: 3,222, Level: 23 Points: 3,222, Level: 23 Points: 3,222, Level: 23
thanks for the mod man. i bought some grill inserts and i was hearning that the ones you buy fall off alot so i like this idea , looks like it should be pretty sturdy.
TWEEKIN is offline
post #4 of 16 Old 07-19-2007, 06:58 AM
Random Hero
XxLoFnKtAxX's Avatar
Points: 13,576, Level: 50 Points: 13,576, Level: 50 Points: 13,576, Level: 50
Send a message via AIM to XxLoFnKtAxX Send a message via Yahoo to XxLoFnKtAxX
Originally Posted by Alta Boy View Post
Poor bee under your grill
XxLoFnKtAxX is offline
post #5 of 16 Old 07-19-2007, 03:23 PM
Points: 1,385, Level: 14 Points: 1,385, Level: 14 Points: 1,385, Level: 14
LOL I was looking at that to...That bee got by your Dakota..
KOTA is offline
post #6 of 16 Old 07-19-2007, 04:52 PM Thread Starter
Ha ha ha ... You guys are too observant sometimes.
post #7 of 16 Old 07-19-2007, 05:25 PM
Points: 592, Level: 8 Points: 592, Level: 8 Points: 592, Level: 8
Dumb question but how do you actually get to it when the hood is down?
nitwhit0921 is offline
post #8 of 16 Old 08-04-2007, 09:20 PM
Points: 785, Level: 10 Points: 785, Level: 10 Points: 785, Level: 10
never even thought that would happen while building my grill. Good thing it doesnt affect the older dakotas.
JunglisticDak is offline
post #9 of 16 Old 08-04-2007, 09:24 PM
AM*E*LL's Avatar
Points: 5,405, Level: 31 Points: 5,405, Level: 31 Points: 5,405, Level: 31
is that 2 different inserts on each side?
AM*E*LL is offline
post #10 of 16 Old 08-04-2007, 09:27 PM
Whore King
Points: 22,688, Level: 65 Points: 22,688, Level: 65 Points: 22,688, Level: 65
The front end looks sick!
2000 Club Cab SLT 2wd
2004 Club Cab SLT 4x4
00dakota is offline
2nd gen shaker hood crazy93dakota Body Work Forum 16 08-06-2008 11:42 AM
Know how to suicide the hood???? MoparJoey Styling Forum 7 06-21-2007 09:36 PM
'99 hood latch relocator 99Lowkota Wanted to buy 4 11-08-2006 04:31 PM
fiberglass hood help reconstrucktion Body Work Forum 0 09-11-2005 05:34 PM
Reflexxion Cowl Hood Group Buy! vegasoutkast For Sale 1 12-15-2004 07:07 PM
