Low budget fog light install - Dodge Dakota Forum : Custom Dakota Truck Forums
Styling Mods How to articles only
post #1 of 14 Old 02-22-2010, 08:13 PM Thread Starter
Points: 330, Level: 6 Points: 330, Level: 6 Points: 330, Level: 6
Hey everyone. Continuing my tradition of showing how to do relatively cheap mods, I present you with my fog light installation.
These are the lights I'll be using. They are 3" lights. I had seen a bunch of blue colored lense lights, but I thought they would look tacky. So I shopped around a bit and found these at Checkers (O'Reilly) SKU Number is 28845-23062 for any crazy person who might be asking for sku's
This bit was found at Home Depot, fairly easy to find, it's in the same aisle as the rotary cutters.
This is what the bracket should look like. If not, this whole thing should still work for you, you'll just have to modify your drilling.
I hope this picture makes sense. If not, just look behind your front bumper directly behind where the fog lights would be. It should make sense then. Don't automatically drill your holes (1/8" drill bit) in the same positions as mine. Test fit the lights and make sure they are in a position you like. I wanted mine to stick out a little, so if you want yours to be recessed or flush, you may end up drilling a little further back. Remember, the bracket does allow for about an 1/8" of adjustment forward or backward.
This is the screw setup you will need. These don't come in the kit, so you have to get them yourself.
This is what the setup would look like on the car. Put the bumper mount between the bracket and the flat washer on the nut side.
This is what the bracket should look like when mounted. It will be a little crooked like how it is in the picture.
When installing my lights I wanted them to match my new https://www.customdakotas.com/forums/...s-3rd-gen.html. The included bulbs give off a yellowish light, and I needed more of a white light, so I got these.
Don't remember the sku on these because I actually took them out of some lights on my Ram. I do know that they are Hella brand and cost about $18 at Advance Auto. This isn't anything you need to do, but if you do plan on changing bulbs, this would be the time to do it.
This is the back of the light with the included bulb.
Here it is with the new Hella blue light. As you can see, the connector at the back is different.
Putting the light back together.
This is the connector that came in the kit. It is designed for a round terminal, not a flat blade, so I had to change it.
Attach light to bracket and then move on to the other side!
Here's what it should look like when you're all finished. Pretty spiffy.
If you don't buy the bulbs, you will spend $19 on lights and $4 on the cutting drillbit.
If you buy the bulbs, add on $18 and you get a grand total of $41
tcory is offline
post #2 of 14 Old 02-23-2010, 12:22 PM
Points: 7,499, Level: 37 Points: 7,499, Level: 37 Points: 7,499, Level: 37
this is something i do on a regular basis at work, but i must say that you have done a great job breaking out steps and including pictures for those who may not have much experience.
A leader without followers is just a guy taking a walk.
madmopar is offline
post #3 of 14 Old 02-23-2010, 01:28 PM Thread Starter
Thanks. I actually did this about 9 months ago, but after putting in my headlights, I decided to change the bulb so I figured I could make a little how-to for people.
tcory is offline
post #4 of 14 Old 02-23-2010, 06:19 PM
92 Dakota 3.9 2wd
KRIS05VVTi's Avatar
Points: 947, Level: 11 Points: 947, Level: 11 Points: 947, Level: 11
Send a message via AIM to KRIS05VVTi Send a message via MSN to KRIS05VVTi
very nice diy broskii!
Originally Posted by 94mark3 View Post
He's from Newark, I believe it. Lol
KRIS05VVTi is offline
post #5 of 14 Old 02-23-2010, 07:34 PM
daknut's Avatar
wow great details in your how to threads. great job man.
daknut is offline
post #6 of 14 Old 02-23-2010, 08:09 PM Thread Starter
Thanks. It's hard to follow a how-to that's too vague, so I try to make mine easy to follow.
tcory is offline
post #7 of 14 Old 02-23-2010, 10:41 PM
Another a+
and I chuckled at the sku for a crazy person comment
post #8 of 14 Old 02-24-2010, 12:11 AM Thread Starter
Another a+
Gotcha covered.
tcory is offline
post #9 of 14 Old 02-24-2010, 03:31 AM
Nice write-up but you should include an SKU number for the electrical female spade connector so the SKU challenged don't get confused.
post #10 of 14 Old 02-24-2010, 11:04 AM Thread Starter
Haha ok I'll try to keep that in mind.
tcory is offline
How To: Putco LED Dome Light Install. XxLoFnKtAxX Styling Forum 17 12-11-2018 06:33 PM
LED info, FAQs, tips and tricks brightwhiteR/T Styling Mods 4 11-11-2009 05:46 PM
low fuel light Scooby I have a Question? 7 07-17-2009 09:10 PM
Turn/signal Bulbs for 06 lilbrucie Styling Mods 9 03-09-2009 08:42 AM
Ram 3rd Brake Light in Dakota 3rd Brake Light ecordell Styling Forum 4 01-09-2007 05:29 PM
