different intakes - Dodge Dakota Forum : Custom Dakota Truck Forums
post #1 of 5 Old 12-03-2010, 08:02 PM Thread Starter
Points: 875, Level: 11 Points: 875, Level: 11 Points: 875, Level: 11
different intakes
this may be a dumb question. i'm not too engine savvy, but what's the difference in these two intakes?
isn't the point of an intake to draw in cooler air? the dual intake looks like it'd sit right above the engine taking in hot air making it contradict itself. but i did see it on a users truck here on this forum i think. just curious of the main differences as i'm going to purchase one soon i think.
sorry for the noobness haha
-Torres- is offline
post #2 of 5 Old 12-03-2010, 08:13 PM
the idea is almost any aftermarket air intake is going to be able to draw in a larger volume of air, and reduce the turbulence of that air. Stock intake systems are designed to quite the noise of the incoming air and to fit nicely in the space available.... in addition to accommodating various sensors/hoses.
We can argue the heat thing for a month and get nowhere.... sure the longer tubing might get air a few degrees cooler but once the tube heats up there probably won't be much of a difference, if any.
My advice is unless your getting an aftermarket hood to take more advantage of the air intake... just choose the one you like the look of best
post #3 of 5 Old 12-03-2010, 08:14 PM
Flame98's Avatar
Points: 1,733, Level: 16 Points: 1,733, Level: 16 Points: 1,733, Level: 16
The position of the filter is really the only difference. the first would be better performance wise i guess and the 2nd i think looks better. Either way youre not going to see a huge increase either way you go. Heres mine, i like the way it looks even if its robbing me some hp plus it was $30
Gibson headers, Spintech ProStreet, Edelbrock air cleaner, 2'' blocks, 17'' R/Ts, fender flares, Tinted signals, tails, and 3rd, Boss 10in, Crunch Amp, Blaupunkt Headunit, Mopar Bedside Decals.
Next: Y-Pipe, 180*tstat, Hight Flow Cat, Keg mod, 50mm TB, SCT, Mopar Valve Covers, 1.7 Rockers, Gloss Black and Metal Flake R/Ts
Flame98 is offline
post #4 of 5 Old 12-04-2010, 01:00 AM Thread Starter
ok cool. thanks for the replies. i figured they'd both be pretty close performance-wise. i'm gonna go with the second one probably.
-Torres- is offline
post #5 of 5 Old 12-04-2010, 09:10 AM
Flame98's Avatar
yeah i think it looks cooler and you wouldnt notice much of a change
Flame98 is offline
Let's see some intakes 94mark3 General Dakota Discussion 20 02-27-2010 04:57 PM
ebay air intakes JimmyJ V8 Performance 8 01-03-2010 06:57 PM
Air intakes ackillies334 I have a Question? 0 04-19-2009 10:34 PM
Volant Air Intakes? KeithBMI V6 Performance 13 08-06-2008 01:41 AM
Prozen Motorsports Intakes 97BlakDak318 V8 Performance 7 04-06-2005 08:41 AM
