how to take off the fan clutch? - Dodge Dakota Forum : Custom Dakota Truck Forums
post #1 of 8 Old 11-13-2009, 06:43 PM Thread Starter
AWD Dak!!! What?!
Points: 815, Level: 11 Points: 815, Level: 11 Points: 815, Level: 11
Self explainitory...lol what exactyly do I losen and take off the manual clutch fan
HazieD1 is offline
post #2 of 8 Old 11-13-2009, 07:41 PM
Points: 4,194, Level: 27 Points: 4,194, Level: 27 Points: 4,194, Level: 27
That Big nut right in front of it!
oops in back of it
KotaChuk678 is offline
post #3 of 8 Old 11-13-2009, 08:12 PM
WHOOOSH!! Right over my head. Pretty complicated explanation Chuck. Can you put it in plain english and layman's terms? lol
Actually it's the BIG nut behind the fan. Just be sure to loosen it the opposite way the fan would normally spin. A piece of wood jammed into the belt pulley will stop the motor from turning over while you free the nut. Some of them take a little coaxing but be carefull you don't destroy the belt or pulley doing it.
post #4 of 8 Old 11-13-2009, 09:56 PM
we had a hit of trouble with 00dak's. the belt kept slipping. we used on of those rubber strap wrenches(pryed against another engine part)
i want to say its a 32 or 36 mm nut, dont quite remember.
post #5 of 8 Old 11-13-2009, 10:23 PM Thread Starter
AWD Dak!!! What?!
Thanks guys appreciate it just wanted to make sure before I f'ed something up
HazieD1 is offline
post #6 of 8 Old 11-14-2009, 08:30 PM
Raw doggin it
01DakSport's Avatar
Points: 1,118, Level: 13 Points: 1,118, Level: 13 Points: 1,118, Level: 13
Send a message via AIM to 01DakSport
good luck man i took it to my shop n we still couldnt get it off i needed a new water pump anyway so i just that..
01DakSport is offline
post #7 of 8 Old 11-15-2009, 07:14 AM
Points: 756, Level: 10 Points: 756, Level: 10 Points: 756, Level: 10
i found if you take an air chisel to the nut on the left side right on the edge it will often get it to break loose and you do not have to worry about holding the belt or anything
wekeisler is offline
post #8 of 8 Old 11-17-2009, 08:00 AM
burganb's Avatar
Points: 2,004, Level: 18 Points: 2,004, Level: 18 Points: 2,004, Level: 18
yeah same here... give it a little nudge to break it loose then it comes off like a breeze
2001 Dakota SLT QC 4x4 4.7L:
3" Catback Magnaflow Exhaust/545RFE Transmission/SUPERCHIP PROG./RhinoLiner Bed/Blaupunkt THA 475/Michelin LTX 265-70R16/KYB Monomax Shocks/Clear Corners/3" PA Body Lift
T-Bar Crank/BFG ATs
burganb is offline
Clutch Fan Removal and elect. fan unuzual kustum I have a Question? 8 02-25-2010 02:09 PM
clutch fan question JJs02DAK I have a Question? 8 11-24-2009 07:20 PM
87 Dak, clutch wont disengage....Help! smack doogle General Dakota Discussion 4 10-11-2009 10:01 AM
Replacing clutch fan w/ electric kacivic V8 Performance 10 08-12-2009 12:39 AM
Clutch Slave cylender lowdak97 I have a Question? 7 05-20-2007 05:52 PM
