so im creative and have no friends, plus im good at fabbing and installations on almost anything automotive, so heres an idea for yall to use if u want
side note-this is for trucks without a factory fog wiring harness
first take off your whole front end..... ok jus your front bumper cover. this is easy but takes a few more minutes but worth it for the best routing and mounting options, jus 6 easy screws and 4 easy clips.
utilize the plastic bumper reinforcement to your advantage, lots of flat squared cubbys and holes to fill to your preference.
i personally went right above the lights
drill a couple holes and screw in the ballast and be ready to zip tie
zip tie all extra wiring but make sure the bulb wire is not zip tied in case you wanna replace a bulb its easy jus to unplug and replace instead of reaching up and cutting zip ties and having to deal with wires when theres no need for it
sling the plug over leaving a little slack in case you have to take the whole bumper assembly off you can jus unplug it
jus route your wires up to your fuse box or straight to the battery with a toggle switch or however you want.
my buddy who helped me out during the whole process
previous owner hit the front on something and bought a new bumper cover but after taking the bumper cover off i saw that the reinforcement bar was bent in and he never replaced either, explaining why my bumper cover didnt line up and was off jus a bit on one side. so i got a new bar on order, till then naked front
Discussion Starter · #6 · (Edited)
bumper cover back on for now till paint next week
ddm 10k h10s that shine off as a in between 6k and 8k color temp but i like it. have xenon halogen bulbs for now will get 10k bulbs for the headlights once i have projectors
we all like pics right
Hi, I see this is an old post but I have a similar problem with a 2005 Dakota I recently purchased. The front bumper/cover is way out of line. Not straight or even across. What or how did you take the bumper cover off? Does that bolt, on the bottom side of the round frame that the bumper is bolted to, have to be loosened? I haven't been able to break it loose.
