If I run 2 air tanks will i have to run 2 pressure switches? One tank is 7 gallon and the other is 5 gallon?:confused:
No, only if you run 2 compressors, as long as the tanks are linked together. It will keep even pressure.
Not true, I am running 3 compressors on 1 pressure switch. It is a Square D pressure swith bought from grainger for around $30. Its adjustable and better than those other green cheap pressure switches.
there is a piece that i bought with the kit, that you bring your positive and negative from the battery and positive and negative from your compressors to the termail and you can run as many compressors that you want. I just wondering how to run 2 tanks on one switch.
nope, just link the tanks.
