I broke my pinion gear with my factory rear-end, so i went to a junk yard to get a new/old one to replace it... when i turn the drivers side wheel forwards the passenger side turns backward.... but when i turn the part where the driveshaft connects both wheels turn at the smae time, so i was thinkin that i just got another 3.55 rear-end..... well i got it home and took the service plate off and checking it out to make sure it was solid, and the ring gear had 3.90 stamped on the side of it..... and i counted the ring gears and pinion gears and i had 39 ring gears and 10 pinion gears so its a 3.90 rear-end but what i was thinkin is dodge only made limited slip 3.90's..... what kind of rear-end did i get... limited slip, posi, open diff.?????? can anyone help me out here..... o yea i did a "road test" :) and it spun pos 3 times in a row but only if i break torque it
i dont no it catches POS everytime i do a burnout even if i just take off from a deadstop
