1 - 4 of 4 Posts
Since this is my first time installing air bags, I opted to stick with the leaf springs. I thought it would be cheaper and easyer. I used new shackles and hangers and drop blocks. Quite a pain to install and actually became quite expensive. Within a couple weeks I realized what a krappy ride and much better off I would have been with a 4-link. I've decided to get a paralell four link from suicide doors. In the description it says they are made to order. For you guys with parallel four links, got a few questions..
They mount on the outside of your frame to the axle right?
Second what length bars are you guys running. They are built to specifications. In order to order need to know what length bars. Cant put it off much longer any info would be good.
hmmmmmmm I used jasons four link but I didn't use the brackets ...... Instead just the ones for like a tri..... i can measure the bottom ones 4 you to get a better idea of what you need 2morrow
1 - 4 of 4 Posts
