G
i'm wanting to bag my truck,but i have no bed cover. Will it be ok to let my compress sit out in weather or would have to make some kind of box for to cover it low on funds ?!
The majority of compressors Ive seen have a sealed motor, so they should be ok under normal weather conditions. You just might wanna run a covered type air filter to keep the rain away. Hope this helps.
most compressors i've seen as well are commonly monuted under the bed in open beds uncovered and never have any problems...just run a good filter and you should be ok......warranties are good too.
G
got any pics of under bed. for ideas how i can do it. what would be considered a good filter. thanks for the help
i called AIM. $1252 for the kit that is in Mini Truckin ( minus the over the axle bracket ) and with a 4 link that is delivered should i buy it help please
i say build whatever you can an get the stuff you need by ordering it.....the only things on my air ride i bought were the tank, compressor, lines, and bags, and switch box. Made my own 4 link made my own brackets, made my own notch. Etc etc.....if you do it mostly yourself you will have much more pride in your truck.
don't have the skills, my friends are helping they can weld. it is easier for me to buy that stuff let us put it on. Due to the way i work !afro
