1 - 4 of 4 Posts
Wussup, DaneMan, you are going to need a little bit higher offset than that especially if you plan on tucking rim or even tire.I have 18x8.5 with a +38mm offset and I had to trim the f*** out of my rear wheel well to get them to tuck and it eventually buckled my bedsides.I would recommend at least +42mm or higher if you want to tuck rim. good luck. !afro
definately shorten tha rear end .......
1 - 4 of 4 Posts
