I Have A 92' Dak And I Need Bag Brakets For The Front Does Any Body Know Were I Would Be Able To Find These If So List Some Links Plz Thanx
i am assuming that the older daks use the same set up as mine, just use bag cups for a fullsize chevy, fits fine.
depending on ur wheel size i run 17's with 245 45 17 inch tires, and i used universal cups from FBI, they will put u about 3 inches off the ground, to lay out on 17 or 18 with a lower profile tire set the bottom cup in the lower control arm, make a hole the same diamater and recess the cup almost flush with the control arm, cut 1 inch off ur upper cup, or if u have bigger wheels that will take a little more cuttin, and to keep the top cup from movin take a piece of thread all and screw a nut on 1 end, weld the nut, then add a lock wassher and another nut, put that through ur shock hole and then washer,nut,lock washer, nut it
nogee2, I don;'t see any bag brackets for G2s on that site...
Bk
