1 - 4 of 4 Posts
If I put 20's on my truck will I get a good drop out of it?
I'm bagged right now with just cups up front and a behind the axe w/ monoleaf and c-notch in the rear.
First what year is your truck? If you choose the correct offset for the 20 and the correct diameter tire then they will tuck and all will be good, otherwise expect to kick yourself many times.
j
Well depending on what you set the truck up for when you bagged will have alot to do with it. If you set it up for a small tire then putting something bigger on will not let you go as low. If it's setup for a bigger tire you should be just as low as it is now.
it's a 1997 Dakota. I set it up for 14" wires at the time, but decided to go with a bigger rim this time. I'm going to go the extra mile and bo a notch then. Thanks.
1 - 4 of 4 Posts
