Does anyone have good tips for detaching the power window control or the latch linkage? I installed my driver's side speaker tonight and both of those were a PITA and we actually broke the clip off the bottom of the window control
I assume for a 97?
Once you get all the screws out of the door panel, lift up on the panel to get it loose and then pull the top out. You can slip your arm down and reach the latch, then pinch the clips for the window switches and push up and the switch panel will come out, if you turn it sideways you can put it back through the hole and then remove the panel without disconnecting the wiring for it.
