1 - 15 of 15 Posts
idk what gears i have in my dak stock but its a 2000 sport plus 3.9L im pretty sure i got 3.55s and i wanna switch to maybe a 3.92 or 4.10. is the install something i can do? would it be easier to find a whole rear axle at say a junkyard with the 3.92s and just swap them? what kind of shop would change the gears if i cant do it?
If you look in your glove box it will tell you. My 2000 sport only has 3.23 gears. Unless you are a mechanic don't try it yourself. The gears have to be shimmed properly so that the teeth mesh right. You may be better off looking for a whole rearend. A shop will probably charge a minimum of $250. I'm in the same exact boat right now.
this may be a bit off a thread jack but im runnin 3.55s in my 4x4 do the 4.10s improve accel or topend? and do they make 'em for the 4x4s?
Member of Team Awsome
well this thread is 4 years old
yessir! i have no need for top end. i run mud terrains and the vibrate like hell anything above 90. but they are only rated for 90 anyway. Anyone know where i can find a 4x4 4.10 setup?
"Do What You Do"
its usually like that for a lot of things. i think i a have a buddy that can do it. if not i think ill stick to my stock ones. im trying to be that fast. want a truck that is loud and low.
1 - 15 of 15 Posts
