I just got my Frame patch from the old rack and pinion pulled out of the frame on 1989 Dakota convertible.
It is on now.
Any suggestions? or Ideas?
It is on now.
I was put on the Power steering pump. The bolt hole on the timing chain cover for the pump was dirt. I clean it out with a eye glass screw driver with little pressure. I poked a hole thru something by accident, all my antifreeze came out in a stream.
The question is what is behind the timing chain cover... I hope a Freeze plug. I am just starting to remove my radiator to remove water pump and timing chain cover to see what it is I poked?
