O.k. here goes, I just purchased an 02 extended cab Dak. V6 model. and I have plans on doing a full airbag set up. F.B.S.S. 2 - 7 Gal tanks, 2 Compressors, 8 - 1/2 inch valves, lines. I think I'm going to do 2600 lb. Slam Specialties Bags. and 4 link. The problem I have is, this is my first truck, I've never had a vehicle with bags and I want to do it right the first time. Now the last car show I went to was in Tampa, Florida. at Slamfest. and just about every dakota I saw there was slammed, laying frame on 20's. almost all of them, had shorten the ax in the rear, and also had special billit rims so they could tuck in the back and front. Is this something that I'm going to have to do??? I really don't want to shorten the rear ax if at all possible. I'll be honest here, all I want to do is lay frame and throw sparks all day long!!! can someone tell me exactly what I can expect and what is the easiest way to do this, with minimal cutting.<--- HAHAHAHA, Yeah, Right!) I just don't want to mess anything up. And what should I expect? How did you guys do your set up? Did you guys do it yourself? or did you have a shop do the work for you? Most important, How long does it take to do the whole thing? Any info would be helpful, I did look at the other posts, and got some great info, but I wanted to hear your experience, good or bad.
Thanks in advance, Charles !afro
